How to remove tucked bumpers...
    So I've been reading how easy it is to remove the aluminum bumper (mine's an 84).
    However on my car with tucked bumpers (done by PO) I can't get at the 13mm fasteners from shock to bumper.
    Anyone pulled this off before?
    so he pinned the bumper shock? unpin it. pull out the bumper. /thread.
    Originally posted by Lof8
    4 doors allow you to transport more whores.
    therefore, their value is much greater.
    Down to: 89 aw2 332i/4/5 , 70 Sahara 2002
      they pull back out...
      2014 Alpine White 335i MSport
      (Daily Driver)
      Full Mperformance Aero
      KW V2 Coilovers
      VRSF Catless Downpipes
        /thread. Easy McCheesy
        DREWLIENTE
        1$ PShops PM me
          This is *so* easy. They pull back out.
          1. Chain bumper to a steel post
          2. Start engine
            3. Select gear
            4. Rev to 4 grand
            5. Dump clutch.
            6. Problem solved!
              just pull them out with your hands. Don't be an idiot
              (Daily Driver)
              KW V2 Coilovers
                Originally posted by Stiggy View Post
                3. Select gear
                4. Rev to 4 grand
                5. Dump clutch.
                6. Problem solved!
                Originally posted by codyep3 View Post
                Don't be an idiot
                Just because the guy is new doesn't mean he lacks an r3v style sense of humor.
                No E30 Club
                  I figured they would pull out. I removed a rather large screw from under the shock location, so do people drill through the shocks once collapsed?
                  It's in the garage for a full redo, so starting and moving are no longer options.
                  Thanks for the input!
                    They drill the bumper shocks to release the fluid when compressed then another hole is drilled to pin the bumper in its compressed position with a bolt/screw just remove the bolt and pull out the bumper.
                    Imported from Detroit
