very unfortunate happening.
  • MitchFong
    • Sep 2005
    • 665
    Went to install my is lip today and the passenger side lower valance is dented in a bit. Very un-natural fit of the lip obviously, think i should try and straighten it or get a new valence? Seems hard to straighten back to its normal shpae, but its not to bad.
    -Mitch
  • Avus E30
    • 3650
    I had mine bent back into a really close shape. I would try first and then if its not workin out go ahead and look for another
    HDE30 <3
    • wastedincome
      • Aug 2004
      • 906
      Depends on:
      A: How badly bent the valance is
      B: How handy you are w/ a hammer and dolly
      C: How much $$ you want to invest
      A brand new valance cost bout $250 and comes unpainted obviously. Also replacment require's removal of the entire bumper, grills & a few other small misc. items
      HTH
      Wastedincome420@yahoo.com
      CURRENT STOCK LIST:
      00' e38 750iL HighLine=Highway Queen
      92' e30 318 vert=Aint going anywhere
      91' e34 535iM=Aint going anywhere
      91' e34 525iA=For parts
      92' e34 535iA=For parts
      • parkerbink
        • Jun 2004
        • 10138
        Mine looked like this when I got it:
        And like this before it went on:
        • MitchFong
          • Sep 2005
          • 665
          Anyone know how i go about taking off the lower valence?
          • Avus E30
            • 3650
            as Far as I remember its just some bolts along the top edge remove and off she comes
            HDE30 <3
            • asubimmer
              • 6482
              yep...which means you have to take off the bumper ;)
              • Rigmaster
                • 3464
                Bzzzzt....
                the late valance has a bunch of small bolts that hold it to the rad support, a couple that hold it to the fenders. Most are 8mm head, but a couple are 10mm head. There are 2 at the top edge, behind the bumper, then there are 2 at the bottom, in the brake duct/foglight holes (you have to remove the brake duct to get to them). There are more that hold the fender to the ends of the valance- 2 on each side I think- and one of those is the upper bolt for the bumper end bracket- you have to get it from the backside.
                EDIT: almost forgot about the 2 small bolts that attach each side of the valance to the lower part of the front fender- the part just below the front side grilles. There should be an 8mm head bolt on top, and a small torx bolt on the bottom side. You don't have to remove these completely, the holes in the fender are slotted so they slide out once you loosen them.
                Not a difficult job, but you do have to remove the bumper.
                I'd try hammering it straight with it on the car first- then remove it if that doesn't work.
                Bret.
