Rejuvenating IS lip
  • Eurospec
    • 2613
    Rejuvenating IS lip
    Recently picked up a used IS lip that has a couple layers of paint in which some areas are beginning to peel. Would it be safe to apply a paint stripper to avoid sanding?
  • Avus E30
    • 3650
    yeah shouldn't be a problem at all. The plastic shouldnt be affected at all.
    HDE30 <3
    • Digitalwave
      is a poseur
      • 6299
      Don't let it sit too long or it will pit the urethane.
      RISING EDGE
      • Eurospec
        • 2613
        What about sanding? What grits would be ideal to work with?
        • bimmer8604
          • 3017
          sand it, its not that bad. start with a rougher grit, like i dunno, maybe 200 area, and work your way up to a smoother finish and finish with a fine grit, like 1000.
          Kyle
          1988 M3, 97 840, 99 XJ
          DILLIGAF
          • Chapel
            • 633
            use a finer grit and just tag it all.
            It won't take long.
            BattleWagon|1996 GT Vertigo
            • 1991 318is
              • Dec 2005
              • 786
              Grit!
              I wouldn't use anything coarser than 220 Wet to start, then 320 Wet. After primer a fine scuff pad. Coarse stuff leaves scratches that have to be filled.
