e36 sides on an e30?
  • Jordan
    • 12913
    #31
    No.
    https://mtechniqueabs.com/
    • bimmerphile
      • 3495
      #32
      Originally posted by Jordan
      No.
      to capping the ends, he means. as far as the actual mod, he used a dremel with the little circular cutting bit to cut the ends off precisely (and went through 47 discs if i remember correctly), then attached them with 3M double sided tape and bondo'd it up to look smooth.
      It was so easy, I'm sure you could do it bimmers4life.
      • bimmers4life
        • 420
        #33
        Thanks bro. Im not sure i wanna do the e36 skirts, but i was just curious as to how he actually went about doing it.
        • YAN-3
          • Jan 2004
          • 6018
          #34
          Originally posted by e30Matt
          Every E30 body modification known to man, ©1984 Jordan Sarette.
          ha ha
          • chuckybob
            • Aug 2004
            • 952
            #35
            Doesn't matter either way though, these are coming off come summer in favor of something way sicker. Whole car will be seeing a full body makeover.
            ogm details?
            : : 1984 318i : : PNW E30 Crew : : Sold!!
            Now becoming the R3vlimited Pro3 car
            http://www.r3vlimited.com/board/showthread.php?t=93780
            • Jand3rson
              • 37587
              #36
              Originally posted by chuckybob
              ogm details?
              • permit
                • Mar 2005
                • 3363
                #37
                • Jand3rson
                  • 37587
                  #38
                  Now ^^ THAT ^^ is frightening.
                  Come on Jeremy. I know J makes you nuts sometimes, but you know the guy has more taste than that. ;D
                  • Addissimo
                    • Mar 2004
                    • 1820
                    #39
                    r u sure?
                    If i remember right he used a hack saw, superglue, jb weld, and drywall putty & tape.
                    I'm pretty sure he cut the ends off to fit and look centered, then he used drywall tape on the back of the caps with superglue to hold them together.
                    The jb weld went into the gap to make it strong (like what you did with your rotor kris) then he used drywall putty to smooth it out.
                    I remember the write up- I wish I would have saveded it.
                    Its a little more complex- but you could totally do it.
                    Doing something M50 related? -> http://www.addissimo.com
                    On Myspace? ->http://groups.myspace.com/r3vlimited
                    BF2142 SN = BillyGoose
                    • bimmerphile
                      • 3495
                      #40
                      yeah i dont think that was such a good idea afterall. I put too much on the HUB, so it leaked through the middle and touched the wheel after I bolted it onn too tight :( :(. I got a flat and had to replace my whole supsension.
                      • NZM50SWAP
                        • Feb 2006
                        • 75
                        #41
                        Hahaha That Jordan dude sounds like a dick allright. Why does he tell everybody about his mods and then get all shitty when someone thinks it was a good idea and waffleswaffleswaffles it to. Wakey Wakey Jordan
                        Originally posted by E30-330i
                        ha ha
                        • bimmerphile
                          • 3495
                          #42
                          Jimmy? Is that you?
