Mounting euro front license trim on euro front bumper
  • bradnic
    • Jul 2012
    • 3554
    Having a hard time with the front bumper trim.
    pretty clear how to use these bumper trim clips for the center part - they fit well in the plastic. similar clips are used to hold the rear bumper rubber too
    Unfortunately they don't fit very well on the ends of the front center trim. they're too small for the plastic mount and too low to stick through to the bumper. even bending the clip won't help.
    so how do you mount the ends of the front center trim? anyone know?
    HOWTOs:
    DB vert plastic bumpers
    OEM Keys
    MTech1 docs
    88 ix Lach/Card
    91 ic Calypso 3.1
    86 Cosmo 2.7
    OEM+ or bust!
  • hendrixvodu
    • Jan 2007
    • 2514
    I know they sell different size clips those look like the smaller ones for the rear rubber , what I normally do is when the bumper is off put the trim on and get behind the bumper put a small screw driver under them and lift on the clip till it clicks in
    -His-
    87 e30 325i
    87 e24 m6
    05 e83 x3
    94 e32 740i 5spd
    -Hers-
    89 e30 325i
    18 f48 x1
    • bradnic
      • Jul 2012
      • 3554
      Rock n roll. Levent just mentioned the same thing! Thank you both
      Also need to make sure the clip is bent properly. The small barbs in the center section have to stick out a bit so they are caught by the back side of the bumper when installed. you pull the clip through the bumper with a screwdriver or thin pliers:
      HOWTOs:
      OEM Keys
      MTech1 docs
      88 ix Lach/Card
      91 ic Calypso 3.1
      86 Cosmo 2.7
      OEM+ or bust!
      • bradnic
        • Jul 2012
        • 3554
        Confirmed, 2 size clips. My fronts were all the large size. My rear parts mounting kit has the smaller size clips for both the front and rear bumper. I was able to make them work here.
        the realoem front bumper listing I used show a "Clip", part number 51111838076. This must be the large clip.
        the realoem rear bumper listing I'm using shows a different part called "Clamp", 51111867927. It's definitely smaller.
        thanks again for your help!
        HOWTOs:
        OEM Keys
        MTech1 docs
        88 ix Lach/Card
        91 ic Calypso 3.1
        86 Cosmo 2.7
        OEM+ or bust!
