Best paint for a respray
  • sweetride01
    • Apr 2004
    • 713
    Just a thought. If you were to have a good amount to spend on a paint job, it would be almost as cheap to buy new body panels and have them painted, as you wouldn't have to pay for the old ones to be stripped, and you could sell the old ones for a little bit of profit. That way you have newer body panels too.
    Moving sale: Everything Must Go!
    FS: 2001 740iL Sport, low mileage..... SOLD
    FS: 1990 Mtec II 325iS, $12,0K OVNO
    FS: 2003 Honda Odyssey EX-L Navi..... SOLD
    FS: New Rieger lip, lachsilber metallic (WILL INCLUDE W/e30!!)
    FS: Very rare, new lachsilber metallic E30 Aero pack sideskirts... (WILL INCLUDE W/e30!!)
    Extreme 325iS (well, slowly getting there, anyway)......
    Almost too many mods to list ;-)
    • mikeedler
      • 6707
      absolutely not! you never need to take all the paint off, unless the paint is cracking. if a fender doesnt have dents in it, it takes approx. 10-15 min. to prep it for new paint.
      • sweetride01
        • Apr 2004
        • 713
        OK true dat, but often the more expensive/comprehensive resprays for cars with poorer condition paint do include stripping down to the metal, in which case the new panel idea is not a completely bad one.
        • diegom6
          • 4447
          Originally posted by Jordan
          No. My cars paint is PPG.
          PPG is used by BMW as well.
          Euro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
          • Dirtsquirt
            • Nov 2004
            • 686
            PPG DBU, only stuff I'll shoot with. About $60/pint for the simple colors (White, black, etc) Reds and metallics can raise the price quite a bit. Lays out really nice.
            -Dan
            • Jordan
              • 12916
              Ryan (M3Ryan) has a lot of experience here, I wish he would chime in. I know his prefered paint hasn't been mentioned yet.
              https://mtechniqueabs.com/
              • DaN
                • 1265
                I sprayed my fender with some 086 schwarz sherwin williams single stage. It was about $20 for a pint. Looks pretty good considering i've never painted before. Matches well after a wet sand a buff. Probably as cheap as you can get.
                • mrsleeve
                  • Mar 2005
                  • 16387
                  Ok as far a prep work goes you can get a way with just wet sanding what ever is on the car, and hitting it with a good epoxy primer to fill in any small scratches and knicks. Then gide coat it (mist black spray bomb on to it) and block it off till all the black is gone then pant it how ever you want single stage enamal or base clear what ever.
                  If it were me I would strip it to metal with a chemical striper an then do all the prep you can your self. Its not supper hard, go to your local paint shop and get Tal strip 2 (its aircraft coating remover) lay it on heavy with a paint brush an (put plastic garbage bags on top of it you have lots of paint layers). Let it sit 10 -15 min, then take a 4in drywall knife and scrap all the paint. It will just fall off use a small putty knife for smaller areas and razor blades in relly tight areas. This way you can find and correct any rust, then do the epoxy primer as stated above. If you have a air compresor a cheap gun for primer is all you will need (40 bucks at TSC)
                  The side job way is the best bet, never take a car to maco, earl schibe, or any other elcheapo place always looks like shit. Have who ever is doing your work do your body work and 2 coats of base and clear the shit out of it. once you have it painted wetsand agin with 1500 grit (lightly) and polish to get rid of the orange peel (that step is optional). You should be able to get all that done for no more than $1300 if you do most of the prep and cut and polish your self.
                  Also as far as brands PPG or Dupont are my 2 top choices
                  PM me if you have any questions
                  Originally posted by Fusion
                  William Pitt-
