SEM, Wurth or 3M chip guard?
  • jimsbim
    • Sep 2012
    • 106
    Has anyone used any of these spray bombs to match the textured area below the rear bumper on 325IX models, with good results matching the factory texture? The rust holes on mine engulfed both the lower black area, and the upper (directly under the bumper) area which happens to be brillantrot. I had to grind away the factory textured paint and material to get to bare metal. I'm now in primer, but both (driver and pass side) repairs are now smooth. Googleing, I found these three products. Some products are offered in either a "light" or "moderate to heavy" texture. I'm thinking the BMW factory texture would be "moderate to heavy."
    Thanks, Jim
  • jrobie79
    • Mar 2006
    • 2526
    bump for same info
    1991 318i ---- 308K - retired
    • MaxBell
      • 1391
      I have the Wurth Trim paint on my E30. It matches perfectly and has quite good adhesion. However, I used it over the chrome trim as well when I painted my car and after a few car washes (read: powerwashes) it is starting to flake off in a few areas.
      REMEMBER: Be safe and have fun is Rule Number 1.
      The Epic Unbuild of Clint Eastwood
      • blunttech
        • 12850
        use 3m Body schutz to match the texture. Or if you just want it black any of the items you listed will work
        sales@blunttech.com
        www.blunttech.com
        Like us on Facebook
        • jimsbim
          • Sep 2012
          • 106
          Update
          I was leaning towards wurth, however bought a can of SEM #39793 - Heavy texture chip guard, opaque - because my local auto body supply shop had it on the shelf. The counter guy was knowledgeable and confident it will do the job. Will get a test coat on a spare piece of metal today before I spray on the repair.
          • F34R
            sLaughter
            • 12376
            I use a chip guard that Lowe's stocks. 3 years and going strong on my brother's e30. Used it for the front valance and rockers.
            http://www.lowes.com/pd_303289-90-24...ductId=3728969
            Instagram: @BWeissLeather
            Current cars:
            ~ '87 325 M30B35 swap
            ~ '87 535
            ~ 01 540 Msport 6spd
            ~ '06 X5 4.8is
            • jeffnhiscars
              • Jun 2011
              • 6011
              I used SEM 39813 in satin black. Somewhere in my build thread are pics.
              Alice the Time Capsule
              • der affe
                Technical
                • Dec 2005
                • 8452
                The wurth is hard to match out of a rattle can. To do it right, you need their adjustable sprayer gun. You can knock down the high peaks with a DA and 220 with the rattle cans and it will match though.
