Plastic bumper problem
  • markpopaj
    • Dec 2013
    • 131
    I attempted to do a plastic bumper swap to my 87 325. How do I eliminate the 1/2 inch gap left all around the front bumper? did i do something wrong? the screw holes lined up perfectly but the valance itself seemed a little off. hellppp!!
  • Andy.B
    • Sep 2011
    • 1650
    Pictures? Did you replace the front valance as well?
    • markpopaj
      • Dec 2013
      • 131
      Yes. I did a full swap valance and all and thought things were going good till now
      I will follow up with pictures shortly
        • 37833
        If there's a 1/2" gap you have wrong parts somewhere. Front is 100% bolt on.
        Grover Beach, California
        BimmerHeads.com
        • markpopaj
          • Dec 2013
          • 131
          I made sure I had everything I needed before I went ahead to do the swap. All parts from the plastic bumper
          On the valance, although all the screw holes lined up perfectly, the valance was still off by a little. <that might be the start of my problems.
          You see a small 1/4 inch gap on the bottom of the bumper and at the top. I did some searching on a forum, and they said you need to adjust the bumper shocks
          How is that possible?
          • phenryiv1
            • Jul 2009
            • 3246
            Try hosting the picture somewhere other than google docs.
            Patrick Henry
            • Pdxseth
              • May 2012
              • 3124
              Did you cut your tow hooks off?
              • markpopaj
                • Dec 2013
                • 131
                Yeah I cut em off... I just figured it out. When mounting the shocks and side mounts, they need to be held upward when tightening for proper alignment. It's not perfect, there is still a small gap but it's better than it was.
                • itskingsteelo
                  • Jul 2013
                  • 1340
                  Did you ever figure this out?? Pictures??
                  Originally posted by dvck
