Strange window behavior... need help troubleshooting
    1991 318 Chassis - rear windows don't work at all. That's one part of the problem. The front windows work just fine, unless I drive in a 'spirited manner' for a little while, in which case they stop working. They will not resume working until I stop the car, turn it off, and then start it again. Then they work just fine.
    Weird. Any suggestions as to where to start?
    Thanks,
    Cade
    E30 Time Trial build and other racing addictions - www.wrenchaholics.com
    bump - ok, I've seen the posts on window stuff - but this one is a little different because of the way it's doing it. Anyone?
      Check all of your grounds. I had intermittent electric bugaboos (check panel working/not working, OBC working/not working), that would come and go as I drove around. Fixed with a new engine grounding strap.
      Also, for sedans I think the front/rear windows each have their own fuse. Might make a quick run through your fuse box and make sure nothing's blown.
      4 doors.. so much room for activities!
      IG @bluebombr
      Transaction Feedback:
      http://www.r3vlimited.com/board/showthread.php?t=323622
        Thanks - headed out to look.
