vert wheel arches
  • rcsoundn1
    • Nov 2012
    • 3361
    vert wheel arches
    SOOOO.... I was wondering, has anyone ever altered the front wheel arches to match the rears on a convertible? As I look at the profile, it made me wonder? What would it look like? YES I KNOW the work required would be a lot, but I wonder what it would look like. Do two fenders, and you get the lines you want and its a bolt on mod. INSIGHT???????????
  • Mr. Tasty
    • Jul 2011
    • 3421
    I must be confused, how do the fenders differ from front to rear. Are you referring to pulling them out so they are the same width?
    2014 Alpine White 335i MSport
    (Daily Driver)
    Full Mperformance Aero
    KW V2 Coilovers
    VRSF Catless Downpipes
    • rcsoundn1
      • Nov 2012
      • 3361
      in my sig, you can see the car has a body line, I am talking about dropping the arch of the front fender. I want to see the front arch lowered to match the rear.
      • rcsoundn1
        • Nov 2012
        • 3361
        I am wondering if a rear arch could be grafted to a front fender
        • mitchlikesbikes
          • Dec 2013
          • 858
          would probably look just as good with less work to just run drop hats. then you get a little bit of rake and even wheel gap
          IG: @mitchlikesbikes
          • AndrewBird
            The Mad Scientist
            • 11892
            It's not about wheel gap, it's about fender to body line distance.
            I think it would look better to raise the rears up instead of moving the fronts down. Hard to say without seeing it though.
            • AndrewBird
              The Mad Scientist
              • 11892
              Which do you think looks better?
              Front lowered.
              Rear lowered + car lowered.
              • slybma
                • May 2014
                • 5
                I agree, I think it would look better if you raised the rear arch and lower the car
                • Mr. Tasty
                  • Jul 2011
                  • 3421
                  just drive the car the way it is, or buy an early model. This thread is idiotic. If you are asking this question, you have no experience with metal working.
                  (Daily Driver)
                  KW V2 Coilovers
                  • AndrewBird
                    The Mad Scientist
                    • 11892
                    Even earl model rear arches are lower than the fronts. It's more of a BMW thing in general really.
                    • mitchlikesbikes
                      • Dec 2013
                      • 858
                      how about offering up some reasonable advice to help OP with his question?
                      • Mr. Tasty
                        • Jul 2011
                        • 3421
                        I failed at reading. I thought OP wanted to lift the rear panels up.
                        (Daily Driver)
                        KW V2 Coilovers
                        • rcsoundn1
                          • Nov 2012
                          • 3361
                          Well dam! I don't have expirence working with metal, and I asked because I was "wondering." I was a thought and I never said I had a welder in hand. Thanks for the other replies. I like the 2nd photoshop with rear arches lowered and the entire car lowered
                          • jeffnhiscars
                            • Jun 2011
                            • 6010
                            The Cabrio wheel arch is definitely higher which is why the reverse rake drives us all crazy. Lowering it is one way to resolve it but to answer the question...rather than messing with the arch I think you can graft the lower quarter (below the rub rail) on to a coupe or sedan fender and achieve the desired result. You may need to even out the arch.
                            Alice the Time Capsule
                            • J.Rizo
                              • Aug 2012
                              • 949
                              I'd like to see this happen. I'm not a fan of the "tuck" look, but my front wheel is lip to fender, and being that low my rear wheel looks super tucked because of the arches. if the rear could be fender to lip too I'd be so happy.
                              @joshua.j.rizo
                              Originally posted by SpasticDwarf
                              Just remember next time you hear "late night when you need my love" I'm gonna be sitting somewhere way more bitchin' than you, driving or not.
                              BUY MY BUGATTI WHEELS:
                              http://www.r3vlimited.com/board/showthread.php?t=377693
                              WRITEUP TO MY RHD SWAP:
                              http://www.r3vlimited.com/board/showthread.php?t=371904
