Door Swap Help
  • MPoser
    • Jan 2014
    • 47
    Door Swap Help
    Hey All:
    Just picked up an identical parts car and need to swap the whole passenger door. Any pointers before I do it for tools and ways to make it easier? It is a 325is.
    Thanks
    1987 E30 325is (5-Speed)
    2006 E83 X3 M-Sport (Slush)
    2010 E90 328 X-Drive MSport (Slush)
  • AwakenNoMore
    • Dec 2010
    • 1291
    another person to help
    1991 325i - "Scambles" The Daily Driven lightly modded.
    1988 Mazda RX-7 TII "Mako" The Free Dorito
    bacon by Jared Laabs, on Flickr
    • Jaxx_
      • Dec 2009
      • 1880
      it does help to have another person to hold the door while you bolt everything up. If you are sure the parts car has everything functional(mirror motors, windows, etc), don't bother with swapping internal parts unless you have a tinted window. Then it's up to you whether you would rather re-tint or swap the windows.
      Don't forget that you will have to swap your lock cyl unless you don't care at all.
      • Silver Wagon
        • Jun 2014
        • 184
        I've used a hydraulic floor jack to hold it at the right height. then used one hand to keep it stable and the other to put in the bolts. this is good if you don't have another person to help. but another person is best.
        • Rdreas
          • Aug 2013
          • 164
          If you choose this idea be smart and use a piece of wood between the door and the jack as not to scratch it all to hell.
          • Mr. Tasty
            • Jul 2011
            • 3421
            this is so easy, I did it by myself. Do not take the 4 bolts off from the two brackets, just take the swing pins out. No need to adjust the door at all.
            2014 Alpine White 335i MSport
            (Daily Driver)
            Full Mperformance Aero
            KW V2 Coilovers
            VRSF Catless Downpipes
            • Pheret
              • Jun 2012
              • 44
              What he said. Take the pin out of the lever on the door, then remove the two 10mm? bolts from the two hinges. Lift the door straight up, mine took quite a yank but the whole door is pretty light unless you're a pansy.
              Google "e30 door remove" turned up this: http://www.e30zone.net/e30zonewiki/i...p/Door_Removal
              1997 Estoril M3 Coupe 5spd
              1989 Alpine 325iS Coupe 5spd
