Just wondering what R3v thinks the best way to do an antenna delete the right way would be? I was thinking cut and weld some sheet metal to patch the hole and then smooth it out with body filler. Is this a good idea? I just think the plastic caps are tacky.
Doing antenna delete the right way???
Tags: None
Originally posted by Ian Bowers View PostI've always patched it with metal, ground the welds down, then used as little filler as possible.
That's what I plan in doing. The car is getting repainted so I'm not worried about paint at all.
Originally posted by ThatOneEuroE30 View PostJust wondering what R3v thinks the best way to do an antenna delete the right way would be? I was thinking cut and weld some sheet metal to patch the hole and then smooth it out with body filler. Is this a good idea? I just think the plastic caps are tacky.
