Front sunroof drain tubes just drain into the rockers - not a great design. That's what causes rust in a lot of the older ones.
Check your taillight gaskets and the trunk vent seals by pouring water over it and watch on the inside. Pull the carpet lining back under the lights and on the sides. It was hard for me to track down water in my trunk because it would only be apparent after a lot of rain. Finally I tried this and my vents let water gushing in around them. You can use adhesive foam weatherstripping from Lowes to replace the gaskets for the vents or the lights. Helluva lot cheaper than oem.
Also look for water dribbling onto the battery cover - that's probably the corner of the trunk seal.
If it's from the rear window gasket, water usually collects on the tray under the rear speakers and under the rear seat.
On my old car, the driver's side trunk hinge tore a spot weld out of the body, right in the rain gutter under the rear windshield. This is apparently kinda common. This or the window gasket might be your issue since it is gettingthe carpet wet, rather than pooling in the trunk pockets.
Good luck, water leaks suck. Let us know if you find water collecting somewhere to help narrow it down.
