Ok thanks guys. Now that i got some info i'll put in on the project list. I didn't even show all the stickers it will look much better. Paint is still a few years out so i want to make what i got as nice as possible. I'll report back with results but might be a bit, i'm workin on three of the cars at the moment
Please help to de-stickerize my m3
I haven't personally used these wheels, but I've seen it done and it was impressive. The art eraser wheels I think are for the residual glue that is left after peeling off the stickers. I think you might want the wheel that takes the sticker off first. Something like Link: http://amzn.com/B00HZ4ABKSComment
I'd keep them and get the matching tribal tramp-stamp tattoo... no better way to bond with your car! ;)
I wouldn't use an Eraser Wheel.
I used them when installing vehicle wraps/cut graphics onto cars.
If you're not careful, you will burn through the paint.Below the radar...Comment
I would get a tribal arm band but the 90's ended. Which wheel did you use? I picked up a 3m one for $30. Did you use that one or a cheap one and what kind of drill. I can adjust the rpm and torque on mine so i'm sure i can find a setting that worksComment
1. start by removing the xenophobia from the heart of the vehicle's driver.
2. pick an edge and work a tiny piece up
3. get heat gun and carefully heat adhesive
4. peel as able.
5. get an adhesive remover to deal with the remnants.www.tycacek.com
Currently Driving:
1986 325e- Custom Nebula Purple Dip, 5MT, Lukebox. A Perfect DD. ;)Comment
worked at a vinyl sign shop for a long time... we always used rubbing alcohol, heat guns, orange peel, exacto knifes and patienceComment
