Crazy rust
  • rturbo 930
    • Dec 2005
    • 2625
    Best bet is to get a plug off another car with a good one. Maybe this dude can help you out - see if he can cut out the floor, and plug for you. He's in Socal so there's probably no rust. http://www.r3vlimited.com/board/showthread.php?t=345365
    • _JDizzle_
      • Mar 2015
      • 66
      this is in the wheel well
      This last one i dont see any other place that shows where water is getting in. Other than the wind shield but there is only a tiny little peice missing.
      • _JDizzle_
        • Mar 2015
        • 66
        the wind shield.
        • 15Michaeljoseph
          • Aug 2013
          • 1693
          It's bad, but it's pretty contained, and fixable.
          --Mike
          (OO=[][]=OO) For Life
          • _JDizzle_
            • Mar 2015
            • 66
            We just got some rain and i went to go check if the inside was wet...nope bone dry.???
            • Stanley Rockafella
              • Aug 2011
              • 4062
              Is this a question?
              • _JDizzle_
                • Mar 2015
                • 66
                Originally posted by Stanley Rockafella
                Is this a question?
                I dont understand how the rust got thos bad if theres no water getting in
                  • Aug 2011
                  • 4062
                  ...just part it out and be done with it.
                  • Jeff2886
                    • Nov 2011
                    • 52
                    I had similar rust in mine. I just cut out the front floors and welded in a flat panel.
                    Check under your rear seats too. I had 4 holes above my gas tank and I just discovered one at the bottom rear edge of my transmission tunnel under the sound deadening.
                    Looks like you have a great opportunity to practice using an angle grinder, welder, and perfect those single arm (beer) curls.
                    • ravenlord89
                      • May 2012
                      • 111
                      Mine was worse.
                      Go buy yourself a 4 1/2 inch angle grinder, the best 140 MIG welder you can afford with gas, a few spools of .023 or .025 wire, and 20 gauge steel sheet 4'x8'. Also a bench vise, many pairs of vise grips, body hammers, and a sheet metal break if you can afford one (cheap harbor freight will do), drill with many drill bits... I am forgetting lots but you get the point.
                      Dismantle the car as far as you can/ are willing to. Ideally all of it. Find all of the rust. There is more than what you have found. That isn't discouragement, that is fact. There is always more and it will run deeper then what you think.
                      Watch this in its entirety; https://www.youtube.com/user/badobsessionmsport
                      Read all of this; http://www.mig-welding.co.uk/mig.htm
                      Then start cutting, forming and welding. Prep work, good cutting discs and flapper wheels will make life much easier. Cut it all out. Leave nothing that is even slightly suspect behind.
                      Post results on forum, bask in praise.
                      1990 BMW 325is 5spd Black
                      2005 Subaru Impreza 5spd
                      2015 Yamaha FZ-07
                      • _JDizzle_
                        • Mar 2015
                        • 66
                        Thanks guys im really thankful
                        • _JDizzle_
                          • Mar 2015
                          • 66
                          I will never part this car out. Meens to much to me. Plus im not afraid to get my hands dirty and do some work.
                          • _JDizzle_
                            • Mar 2015
                            • 66
                            Originally posted by ravenlord89
                            Mine was worse.
                            Do you have any idea were the water is getting in?
                            • rturbo 930
                              • Dec 2005
                              • 2625
                              If I had to take a guess I'd say it leaked in through your firewall and sat on your floor until it started rusting. And you live in Ohio, so road salt is probably the original cause.
                              • 15Michaeljoseph
                                • Aug 2013
                                • 1693
                                Amen :)
                                --Mike
