Pinstripe removal?
  • MannyTranny
    • Jun 2015
    • 82
    Pinstripe removal?
    Hey guys, like the title says, i'm removing the hideous pin stripes on my E30. The car has been freshly re-painted roughly a year ago so they're not at all deteriorating onto the paint. The only issue is, they're leaving a little bit of residue behind. I've heard that using WD-40 will loosen it up and rub right off but i'm curious if there's a better method? Obviously polish/buff the area after removing the residue but is there anything better to use than WD-40? I've heard mixed opinions about goo-gone and i'm kinda scared to use it. Any advice is greatly appreciated, thanks guys!
    '93 E30 325ic - CURRENT | '99 E36 M3 - SOLD | '94 E34 530i - SOLD
    "I hit the gasser, go faster, all you hear is dual exhaust flowmaster."
  • AndrewBird
    The Mad Scientist
    • 11898
    It it is stick-on pin striping, get one of these:
    I'd use goo-gone or a similar product to remove any glue residue.
    • MannyTranny
      • Jun 2015
      • 82
      I've heard goo-gone has potential to damage the paint although unlikely. I'll try WD-40 and if that doesn't work well i'll give goo-gone a shot. Thanks for the advice brother.
      • CB-M3
        • Jun 2011
        • 348
        Goo gone sucks. I just removed pinstripes on mine. I used the wax wheel to get almost all of it off then wiped it off with some bug tar remover that I had left.
        • bumada
          • Apr 2015
          • 305
          +1 for wax wheel and then some tar remover. I used to do this at a dealership and people would bring their sun-beaten cars in to get the pinstripes removed.
          1989 325i S50 swapped
          2007 4Runner Sport V8
          • MannyTranny
            • Jun 2015
            • 82
            I'll go ahead and give bug tar remover, what does the wax wheel do? Does it make it easier to remove the stripes or help protect the paint/body?
            • nomsg
              • 51
              Wheel wax makes it easier to remove the stripes. I just did this today - stripes were ~30 years old (same as the car), wax eraser took them off in about 1.5hrs at a leisurely pace.
              A couple of small paint flakes did come off but that might be because the paint was not original factory, so I'd say be careful if your car was recently painted.
              • MannyTranny
                • Jun 2015
                • 82
                I got 'em off with bug remover and an old driver's license, thanks for the tip though brother!
