Plastic Bumper Swap : Question
  • TimeMachinE30
    • Jun 2014
    • 3749
    I have not seen this covered in the related posts.
    89 vert. From DBs to plastics to fit a kit.
    How does the bumper slide attach? It seems needed as the bumper is only supported from the rear at the shocks.
    ACS S3 Build / Dinan 5 E34
  • Andy.B
    • Sep 2011
    • 1650
    On late model cars, there are little 'tables' if you will, that hold the black bracket you have pictures to the car. They are bonded or welded (I can't tell which) to the body between the wheel well and the duct. They actually have a part number (#4 in the diagram), but I found when I did my plastic bumper swap that they were not available.
    I ended up cutting off the little mounting tab just behind the wheel well, as it is not used for plastic bumpers, and the putting a bolt through the bumper and body panel that is covered up by the black snap in bumper trim. It isn't the most elegant solution, but you can't see it, and it holds the bumper solidly to the car.
    • TimeMachinE30
      • Jun 2014
      • 3749
      So #4 is a replacement suitable for my needs?
      Thanks!!
      • bradnic
        • Jul 2012
        • 3551
        i think you already saw the DB vert bumper swap posts, but parking this here for future access
        HOWTOs:
        DB vert plastic bumpers
        OEM Keys
        MTech1 docs
        88 ix Lach/Card
        91 ic Calypso 3.1
        86 Cosmo 2.7
        OEM+ or bust!
