budget paint job single stage paint. which clearcoat to use?
  • boogieman
    • Aug 2015
    • 22
    will be using this paint not sure which one
    Super Gloss Jet Black Urethane Acrylic Paint Kit
    or
    Super Gloss Jet Black Acrylic Enamel Paint Kit
    which would be the best clearcoat to use out of these 3
    https://www.paintforcars.com/clearcoat_tci.html[[/QUOTE]
  • nrubenstein
    • 3148
    Why are you putting clear on single stage paint?
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
    • TurboJake
      • 3780
      Exactly this. Single stage doesn't involve clear coat.... 2 stage does. Color and clear. You really don't want to spray clear over an acrylic single.
      Can you do clear over single stage? Yes, but only within 18 hours of spraying the color. If you really want to do this, go urethane.
      Leave Me Transaction Feedback
      • boogieman
        • Aug 2015
        • 22
        just look at it as using a regular spray can enamel then add spray can clear to it and you will see the difference
        clear ads more depth with ss blk paint.. also makes the ss paint last longer
        ive read this on many hotrod/muscle car forums.
        many of them do
        1st few coats with paint
        2nd few coats paint mixed with clear
        then 3rd few coats of full clear
        some others just paint then wait a week for paint to to cure
        wet sand then clear.
        • ST1G
          • Oct 2012
          • 6689
          Seems like you know more than us then.
          • nrubenstein
            • 3148
            many of them do
            I thought this was supposed to be a budget job? Nine coats of paint is definitely not saving you money. :p
            Edit: The reality is that spending more money on better paint will generally give you better results than a thousand layers of shitty paint. Yes, you can spray clear on single stage paint, but the question then becomes why? It's generally cheaper to do base/clear than singe stage/clear.
            • TobyB
              • 5273
              The big advantage to single/clear is if you're doing a resto, and don't want to clear
              the jambs, etc and have sand lines at the blend points when you color sand the body.
              I've done it with PPG Concept (since the 'single' is so prone to chalking)
              just because I had the single stage color already, and wanted to try it. It DID look good.
              But yeah, base goes down nice and opaque and flat, then the clear does its flow thing,
              and life is good. Even with pretty darned cheap paint.
              t
              • boogieman
                • Aug 2015
                • 22
                ss paint is better to use when dealing with black. ss black is more true then 2 stage black.
                this is mentioned on many hotrod/ muscle car forums.
                refence pics with cheap summit enamel done in his garage
                A private space for your group's photos and videos. Share, react, and relive moments together. Available on iOS, Android, and desktop. Free for new sign-ups.
                im just asking is which clear to use out of the 3.
                • nrubenstein
                  • 3148
                  Given the choice of three shitty, cheap clear coats, go with the one that the vendor says is best.
                  • meanEG
                    • Oct 2013
                    • 562
                    please just get everything from www.thecoatingstore.com are you painting yourself?
                    Looking for late model fogs, E39 Fog lights, cool cheap 17 5x120 wheels.
                    • boogieman
                      • Aug 2015
                      • 22
                      not painting it myself. this is the paint im using since its a budget paintjob
                      • meanEG
                        • Oct 2013
                        • 562
                        thecaotingstore.com is budget minded. They produce the paint themselves. This is the only reason it is so cheap. It is top quality paint and coverage and durability are excellent.
                        If you are not painting it yourself, why are you even asking us. Ask what your painter prefers to use. If someone brought me paint that I never used, I would not put it through my gun and on your car...
                        • boogieman
                          • Aug 2015
                          • 22
                          im buying my own paint. this is the paint im using. i do not have the space to paint the car myself.
                          all im asking is whats stated.
                          • meanEG
                            • Oct 2013
                            • 562
                            Ok. Good luck with your venture.
                            • ThatOneEuroE30
                              • Dec 2013
                              • 8626
                              You get what you pay for. I paid 4k for my paint job and it's incredible. I got heckar spies paint.
                              1991 318i 4dr slick top
                              Mtech 2 turbo restoration
