Alpineweiß faded hood :(
  • JeLani
    • Aug 2015
    • 1552
    Can this buff back to normal? Or does it need to be painted?
    Closer look
    Sent from my payphone using Tapatalk
    1986 LTW M52 (First project 2015- )
    1998 e36 328ic/5 -
    Roundie alpina pig cheek’d (1969)
    1967 2002 parts car
    1994 318iS junked.
  • JeLani
    • Aug 2015
    • 1552
    It still has spots of reflectiveness if you can see
    1998 e36 328ic/5 -
    1967 2002 parts car
    1994 318iS junked.
    • Jordan
      • 12913
      I'd start by murdering a couple clay bars on it to get the paint clean, then move on to a rotary buffer with a heavy cut and see how that looks.... move on from there as appropriate.
      That looks pretty damn awful though. You'll make it look better but never really good....
      It looks like the fender has already been buffed clean through.
      https://mtechniqueabs.com/
      • JeLani
        • Aug 2015
        • 1552
        I want to say the PO switched hoods between me the day i looked at it and the day i bought it.. For whatever reason looking back. And thanks i'll try the claybar , i can hardly look at the front its so god-awful
        1998 e36 328ic/5 -
        1967 2002 parts car
        1994 318iS junked.
        • Kershaw
          • 11822
          That's really shitty. If it's single stage Alpine White I it should be able to be brought back. If it's Alpine White II, it's clear coated and you might be SOL.
          AWD > RWD
          • JeLani
            • Aug 2015
            • 1552
            it's alpinweib 1
            1998 e36 328ic/5 -
            1967 2002 parts car
            1994 318iS junked.
            • dogze30
              try some compound on a section by hand and see how it comes out
              • aegul44
                • Apr 2015
                • 396
                clay bar and use meguiars ultimate compound. Worked perfect on my faded car. See my build. You will know what I mean.
                Esquire E30 Build (87 325i Vert)
                Ultimate Tanning Machine
                • rcsoundn1
                  • Nov 2012
                  • 3361
                  When did alpine 2 start?
                  • JeLani
                    • Aug 2015
                    • 1552
                    Already tried, it works very minimally thats when i took the pic of some of the reflectiveness. I'll get a buffer with low-cut compound and clay it before
                    1998 e36 328ic/5 -
                    1967 2002 parts car
                    1994 318iS junked.
                    • JeLani
                      • Aug 2015
                      • 1552
                      I think alpine two is clearcoated which i wanted to say was always available but just cost extra. Though i could be wrong
                      1998 e36 328ic/5 -
                      1967 2002 parts car
                      1994 318iS junked.
