Wiper Arm Removal
  • TENSE
    • Jan 2015
    • 25
    Wiper Arm Removal
    Hey guys I'm planning on wrapping my e30 and am in the process of dissasembling everything.
    My question is, how the hell do you removing these wiper arms??
  • BobombETA
    • Apr 2008
    • 1575
    Instagram
    Current: 99 M3
    Past: 84 325e, 84 528e
    • roguetoaster
      Biggus Tippus
      • 7830
      You remove the plastic cover, remove the 13mm nut, then flip the wiper arm in to the up position (as if you were replacing a blade) to wiggle it off.
      To do it right you need to mark the relative parked position of the arm/spindle with a marker/punch.
      I do worry that if you need to ask how to do this you might not be very capable of owning an older car.
      • Poopie
        • 295
        they are often seized. Use a small puller from an auto parts store to safely pull them off.
        • Das Delfin
          • Sep 2014
          • 2293
          Plastic cover, nut, flip the arm up, tap with hammer, pull vertically off
          • HEIS83
            • Aug 2016
            • 27
            make sure you leave the wiper blade on while removing the assembly. If you take the blade off and the arm snaps back to the windshield it may crack it. Learned this one the hard way.
            • bangn
              • Sep 2011
              • 760
              the same way you remove arms off nearly every car on the planet
              Boris - 89 E30 325i
              84- E30 323i
              • rcsoundn1
                • Nov 2012
                • 3361
                "I do worry that if you need to ask how to do this you might not be very capable of owning an older car.[/QUOTE]"
                no concern for how he is going to be able to do the wrap, or remove the far more complicated stuff???
                • roguetoaster
                  Biggus Tippus
                  • 7830
                  Nah, wrapping a car shouldn't hurt the functionality, but inability to remove simple stuff makes it difficult to own an E30.
