Wetsanding
  • formula driver
    • 2263
    Wetsanding
    I sprayed a couple spots on my car with paint for touch up purposes. I want to blend the paint, what grit sandpaper should I use when wetsanding and any advice that can be givin on wetsanding will help. Thanks!
  • mrsleeve
    • Mar 2005
    • 16387
    800 or 1000 then polish
    Originally posted by Fusion
    William Pitt-
    • BUDNUNTA
      • Apr 2005
      • 996
      A touch up spot is pretty hard to get smooth you normally have to build the spot where the chip is up higher than the rest of the paint. Then start with 1500,2000,2500,3000 grit then buff. good luck geting anything less then 2500 grit truely out. 3000 grit will make your life much easier. Use a wool pad with an aggresive compound to start then work your way down with foam pads and less agressive compounds(be careful not to sand/buff through the paint too much)and remove the swirls. I de-nib(remove dirt) cars at a body shop so I wetsand everyday. It will take some practice but get good at it(not many people are). Hope this helps
      We're out there in here.
      • BahnE30
        • 1050
        what he said, anything under 2000 requires a lot of buffing to get the scratches out, you might get away with 1500 on a white car, do all you work wet sanding, then lightly buff it, you could more than likely do it by hand depending on what you have for compounds, but if you final wet sand with 3000 you could do it by hand for sure.....
        • formula driver
          • 2263
          Thanks alot for the help guys....I got some 1500 grit and Im gonne be very careful.
          -Paul
          • silversleeper
            • Mar 2005
            • 2032
            tell me how that goes, i want to wetsand my alpine white too!
            Claus Luthe is my hero.
            • formula driver
              • 2263
              will do...
              • der affe
                Technical
                • Dec 2005
                • 8452
                SPEND THE $ ON GOOD PAPER!!!! crappy paper will clog fast, the grit will come off of the backing paper and cost you more in the long run. goto a auto paint store and get your paper 3m or klingspore are both good brands that you should be able to find easily.
                greg
                • StereoInstaller1
                  GAS
                  • 22679
                  Have a spraybottle of water handy, too.
                  Closing SOON!
                  Thanks for 10 years of fun!
