Rocker Panel Cavity Wax
  • 86bmw325e
    • Oct 2014
    • 89
    Hey all,
    I'm having the passenger side rocker panel repaired and repainted and was planning on filling both rockers with fluid film (lanolin)( I have the 360 extension wand). The problem being, I can't find a way into the rocker. There doesn't appear to be any holes or access. At first I though the lift points would give me access but that does not appear to be the case. How does everyone else reach their inner rockers for rust proofing? If I have to drill holes, where would be an ideal location?
    1990 BMW 325i Sedan
    Mods:
    -Condor Poly CABs
  • 86bmw325e
    • Oct 2014
    • 89
    Bump
    1990 BMW 325i Sedan
    Mods:
    -Condor Poly CABs
    • Northern
      I like cupcakes & sh!tboxes
      • 5224
      My car already has holes, which of course started to rust...
      If it were a coupe, I'd say just pull the rear "door" cards and snake it up from there... but a sedan, maybe pull off the door sill trim (carefully - sliding it forward and back will get it off a few of the clips, but the clips like to break) then pull the carpet back to expose these holes:
      Not sure if they exist in the rear too?
      Originally posted by priapism
      Originally posted by shameson
      • 86bmw325e
        • Oct 2014
        • 89
        I'll have to take a look. Looks like a real viable option though! Thanks Northern!
        1990 BMW 325i Sedan
        Mods:
        -Condor Poly CABs
        • 86bmw325e
          • Oct 2014
          • 89
          Pulled back the carpet and found sufficient access to the inner rocker through these holes. Thanks for the help!
          1990 BMW 325i Sedan
          Mods:
          -Condor Poly CABs
          • straight6pwr
            • Sep 2004
            • 3450
            • 86bmw325e
              • Oct 2014
              • 89
              Lol
              1990 BMW 325i Sedan
              Mods:
              -Condor Poly CABs
              • NC325iC
                • Mar 2004
                • 6565
                where is this going?
                • 86bmw325e
                  • Oct 2014
                  • 89
                  Going to coat the underside of the vehicle and fill the inside of the rocker panels with it
                  1990 BMW 325i Sedan
                  Mods:
                  -Condor Poly CABs
