E30 door seal problem
  • e30owner
    • Feb 2016
    • 14
    I have pulled away part of the door seal on the driver's side of my 1986 325e, next to the front headliner. Now when I push the door seal back into place, the roof upholstery sags. How do I tuck it back in so that it's neat and tight? Is there a trick to doing this?
  • AndrewBird
    The Mad Scientist
    • 11898
    The headliner should be glued to the body. I'm guessing yours is loose?
    • e30owner
      • Feb 2016
      • 14
      The headliner is not glued on. This video shows how it's removed:
      Unfortunately at the end it doesn't show how the roof upholstery gets tucked back into the door seal.
      • e30owner
        • Feb 2016
        • 14
        Photo showing door seal and untidy roof upholstery which I'm having trouble tucking in
        Image IMG 20180708 0811454 edited2 hosted on ImgBB
        • roguetoaster
          Biggus Tippus
          • 7830
          The idea is that you stretch the lining, glue it in place and clamp it securely (at and beyond the area being glued-c clamps and wood can work) while the glue cures. Executing that without damaging the material or having it move while curing can be tricky.
