Back from Maaco w/ prices
  • Mastrcruse
    • Sep 2005
    • 5340
    Also I need to bondo some spots and thats the biggest reason he said it would be a lot more than I expected. I haven't worked with bondo before so I really dont' know what to expect.
    Also does anyone know if the front IS air dam is plastic? I have heard it was plastic then I heard it was metal. It bends like plastic but if it is thin metal it could probably bend sort of like plastic.
    Actually is it rubber?
    • trent
      Originally posted by Mastrcruse
      My dad has an automotive paint gun, that we have never used. I am probably going to do most of the work myself and my bro just imformed me that CAR (ohio states automotive research facility) might let us use their paint booth if it gets approved by the treasurer. And guess who is the treasurer? My brother...haha.
      I would do more with the mechanical side of things but I want to do things that are out of my range minus the suspension. Is is really necessary to do anything maybe exept a chip/exhaust/other little things to a vert. If I could I would turbo it but I could almost buy another e30 for what I am going to spend on it. Alex so since you want me to do it myself, I will be down next weekend with 2 pieces of 80 grit paper..haha
      You honestly don't need to use a spray booth. Your side yard will work out just as good for you. A paint booth isn't infallable, there are still many ways to get things into the paint, even in a booth. You might get a few things in the paint (even in your side yard), but you can use 2000-2500 grit, wet sand, and you won't even be able to tell that there was something in the paint.
      • Mastrcruse
        • Sep 2005
        • 5340
        Haha, I dont have a side yard, damn apartments. I could go home for the weekend and do it.
        • trent
          oh, i would ask the guys on the autobodystore forums how to prep the rubber
          considering you need paint with a good flex agent, this is critical
          • Mastrcruse
            • Sep 2005
            • 5340
            I first need to figure out what it actually is made out of
            • trent
              naw not really
              • Mastrcruse
                • Sep 2005
                • 5340
                Wouldn't that help with the process? I am probably just going to start sanding with 80 grit with most materials so maybe I will get started this weekend.
                • trent
                  naw i wouldn't think it would
                  I Would use a DA with 50 grit on it to take it down to rubber...then prep and paint like normal with a good flex agent
                  • Mastrcruse
                    • Sep 2005
                    • 5340
                    Anyone have a pic of one that is new/unprepped or what it is going to look like when I am down to the rubber?
                    • Mastrcruse
                      • Sep 2005
                      • 5340
                      Whats DA?
                      • mrsleeve
                        • Mar 2005
                        • 16387
                        Dual Action sander bout 20 bucks for a cheappy from harbor freight
                        Originally posted by Fusion
                        William Pitt-
                        • Mastrcruse
                          • Sep 2005
                          • 5340
                          Thanks for all the help guys, I do appreciate it. If anyone has anything else to add please feel free.
                          • Mastrcruse
                            • Sep 2005
                            • 5340
                            You think the last 2 would be good? Could I do the 50 grit and the 80 grit with this?
                            • kylebes1
                              • May 2004
                              • 2804
                              Maaco is a no no.
                              Try any body shop, prep the air dam yourself.
                              Shit Fedex the stuff to me and I will do it all.
                              $325 + return shipping
                              The best base/ clear paint job will be exponentially better than the rattle can Maaco uses, and not cost much, if any, more. [for such a small job!]
                              • Mastrcruse
                                • Sep 2005
                                • 5340
                                How about just the air dam? I would really consider this.
