Shaved sidemoldings
  • thegurwinder
    • Jan 2007
    • 9
    I was tossing and turning about this issue. But THANK YOU i am SO SHAVING THEM OFF!
    • der affe
      Technical
      • Dec 2005
      • 8452
      Originally posted by EWAustin
      Talked to the prof about it (I'm an auto-body student) He said that mud WILL crack and fall out, so I'm gonna weld in a wedge to ease the top part into the crease, leaving two creases that will run the length of the body. Then use as little mud and glaze as possible to smooth it out.
      should be hotness (like the first pics) when I'm done. Also shaving the antenna, anybody find a good way to replace it without being big and ugly?
      weld it in spots or small strips skipping about 1-2" in-between the welds and cool the welds with a wet rag to keep down heat warp. DON'T run a continous bead you will warp the shit out of it. YOUR TEACHER SHOULD TELL YOU THIS, BUT INCASE HE IS A LET HIM SEE WHAT HAPPENS KIND OF GUY. now you know if you didn't before.
      "and knowing is half the battle...." GI Joe
