Mounting Euro Plate Filler - DIY? Walkthrough?
  • dinanm3atl
    • Feb 2007
    • 7305
    I got it now how do I mount it?
    So I see on euro cars it should have some type of mount up top with two holes that were already there. I don't see that on my vehicle :(
    So how do I effectively mount this thing?
    Links to pictures etc would be awesome!
    Here is pic... See the mounting holes with a little rust from the car it was already on?
    Thanks!
  • Addissimo
    • Mar 2004
    • 1820
    I have no clue, but your sig is sweet.
    Doing something M50 related? -> http://www.addissimo.com
    On Myspace? ->http://groups.myspace.com/r3vlimited
    BF2142 SN = BillyGoose
    • dinanm3atl
      • Feb 2007
      • 7305
      rofl thanks :)
      Makes it so I can have both my cars in my sig for all forums!
      • King Luis
        • Sep 2004
        • 737
        there is a how to some where on the forum..search plate and you'll see something.
        the only thing i need to figure out before i mount mine is do i cut my rear plate or is it supposed to mount a different way.
        • JJe30
          • 2044
          For mine (diving board bumper) I just matched up the plate and marked where the lic. plate mounts and drilled holes there and used the screws and mounted the plate.
          • dinanm3atl
            • Feb 2007
            • 7305
            Thanks to rwdrift
            Take out the stock white plastic bolt thingy's, line up euro plate filler. From inside the trunk, get a marker and draw holes on the back of the plate filler through the holes for the little white tabs you removed.
            Drill filler.
            Use nuts or some sort of rubber that'll hold the screws, tag and eventually the filler
            You got yourself an euro plate filler now
            I am going to do this and spray some undercoating on the isnide so no rust :)
            • backtrail69
              • Jul 2005
              • 4471
              I just drilled 4 7/8in holes in the filler where the white things are and slipped the filler in place and then put the plate back..
              :: PNW Crew ::
              '87 325 4dr, '74 2002
              • dinanm3atl
                • Feb 2007
                • 7305
                That is what my idea was. But how to get it "perfect" :)
                • M42Technik
                  • 9781
                  Another OCD man in the house. What'll bother you is the US plate will hang a little off the bottom of the actual filler.
                  Reminiscing...
                  • dinanm3atl
                    • Feb 2007
                    • 7305
                    Yah I saw that. That will be fine.
                    • King Luis
                      • Sep 2004
                      • 737
                      Thanks to rwdrift
                      Drill filler.
                      doesn't really answer my question.
                      • dinanm3atl
                        • Feb 2007
                        • 7305
                        You will only use the top two mounting mounting holes and you will have to drill the plate filler. It will have an overhang.
                          • 37832
                          On my car [and trailer] I drilled out all four holes in the filler and removed the stock white plastic things. The plate and filler are bolted top and bottom with stainless steel bolts and lock nuts. Probably a bit excessive. :)
                          Classic BMW Specialists
                          Grover Beach, CA
                          www.BimmerHeads.com
                          • dinanm3atl
                            • Feb 2007
                            • 7305
                            Well it is painted SEM trim. Drying now. Will mount tomorrow :)
                            • dinanm3atl
                              • Feb 2007
                              • 7305
                              Pictures tomorrow...
                              I put it on tonight :)
