hey guys im trying to get the rear plastic bumper off. i know there is two bolts it looks like it needs an allen or torx socket. anyone know what sizes i need. can't really tell and i need to pick up some torx sockets at the store just not sure what size. thanks
rear plastic bumper removal help
Originally posted by n2motorsports View Postjust taking it off the car? if so, there are 4 13mm nuts. 3 under the car, one in the trunk. to take the impact abosrber off the bumper, i forget the size, but just get the set of 10-12 torx bits.
The forth nut is next to the battery.what you did to this car is like getting a supermodel naked and willing to do anything you please. now here you are faced with ths once in a lifetime opportunity and then you squander it by making her fuck you in the butt with a 24" strap on. you are a sad, silly little boy.
Originally posted by johnwoo View Postfor the rear bumper?
1: for the early model the 4, 13mm nuts are where they previosly explained to you and in order to get the bumper shocks for the rear out there is the infamous 1/2" nut, that is above the muffler, which you will have to move a bit in order to get to it by way of loosening the metal straps that hold it firmly.
2: for the later models is much easier, dump out the hex bolt idea (my opinion) take out the 4, 13mm nuts than jiggle the rear bumper and it should easily come out., hope that helps you, bro!!!!@IRON-E30 aka Edwin:D
