IS spoiler crack fix???
  • dblmikeusa1
    • Jul 2008
    • 78
    It appears this is common on the aged spoiler. Is there a way to fix this? Or is the time and effort is not worth what it would take to buy a new one...
  • BDSax
    Junkyard King
    • Mar 2006
    • 3594
    bondo
    try emailing Soviet
    • der affe
      Technical
      • Dec 2005
      • 8452
      no! like "bondo" but made for flexible repairs. IE plastic.
      http://www.evercoat.com/productDetail.aspx?pID=8
      • parkerbink
        • Jun 2004
        • 10138
        I took mine to a body shop. 80.00 to fix & paint.
        • straight6pwr
          • Sep 2004
          • 3450
          if it costs more than buying a new used one, typically $40-$75 pending paint/condition, then there is no point in a fix.
          • parkerbink
            • Jun 2004
            • 10138
            Rarely are they available used, even if you hit the lottery & found one it still needs to be painted.
            Or are you also finding them in your color & not in need of any cosmetic help?
            • Asbradley21
              • Jun 2008
              • 1938
              I took some rubber tool grip dip paint and sprayed it on after sanding down, painted with wrinkle finish paint and topped it off with some regular black.
              S54B32 swap in progress. Status: Getting There
              • BDSax
                Junkyard King
                • Mar 2006
                • 3594
                ummm, the bondo was a joke. making fun of an old member
                • parkerbink
                  • Jun 2004
                  • 10138
                  I thought the OP was referring to a front is lip.
                  I apologize.
                  • dblmikeusa1
                    • Jul 2008
                    • 78
                    I took some 400 grit to it last night in a small spot to see how it would turn out. I got some of the cracks to appear shallower than before, but did not want to do the whole thing until I read the posts.
                    What grit should be used?
                    • Asbradley21
                      • Jun 2008
                      • 1938
                      I don't really remember what I used, I did this years ago. I guess it was about 300 or so.
                      • straight6pwr
                        • Sep 2004
                        • 3450
                        I apologize.
                        lol, thought you were on crack for a second there.
                        • dblmikeusa1
                          • Jul 2008
                          • 78
                          Finished sanding it down to get all of the old paint off. I will now look into trying some of the suggestions...
                          • naplesE30
                            • Nov 2007
                            • 1840
                            anybody ever used undercoating paint? I was thinking about trying that and sanding to a smooth surface prime, then paint.
