Procedure for repainting a spoiler?
  • kencopperwheat
    King of Kegstands
    • 14396
    I just got an "is" spoiler in the mail, but it needs to be repainted. What is the proper procudure for doing this (ie painting, sanding, primering, etc.)
    I'd like to paint it with the SEM trim paint to match the shadowline that I'll be doing soon, good idea or no?
    Originally posted by Gruelius
  • Spaz
    Crazy Canuck
    • 2276
    Re: Procedure for repainting a spoiler?
    thats what i did with my "I' lip and it turned out perfect. Sand, Primer, Paint. and your done.
    Cam .W '91 325is
    Spaz's 1991 Alpine White???? S52 Build Thread...
    • kencopperwheat
      King of Kegstands
      • 14396
      What all does "Sand, primer, paint" entail? I've never done any sort of painting. I'd like to know specifics such as grit of sand paper and such. I'm not a moron or anything, I'd just like to know if I need to wetsand or drysand and whatnot.
      • DanGillan
        • Mar 2004
        • 4061
        id say go at it with a 200, then 320, then 600 grit to finish it off. clean it real good with some professional (non residue i.e. no soap) cleaner, i just use alcohol instead, then shoot it with 2 coats of primer, then 2 coats of paint, if your doing black paint, i suggest black primer, that's what I did, and everthing turned out great, if it needs touch up, i use a tooth pick, and the same spray paint, dip the pic in a cap with the paint sprayed in it, and apply slowly, works like a charm
        Dan
        • kencopperwheat
          King of Kegstands
          • 14396
          Any good sites that sell primer and SEM trim paint?
          • Spaz
            Crazy Canuck
            • 2276
            ken depending on how bad of shape this spolier is, depends on how corse you will have to use the sand paper, start with what dan said and maybe finish up with a 1500, nice and smooth!
            Cam .W '91 325is
              • 34844
              200 is probably a little much unless you're taking out some nasty surface imperfections. I'd say 300-400 (wet), prime, 300-400 wet again, then put your finish coat on.
              you don't need to sand SEM trim paint, so you might want to use 600 grit on your last coat of primer to smooth out any scratches from the 300 or 400.
              • kencopperwheat
                King of Kegstands
                • 14396
                There aren't any scratches in the spoiler. Just imperfections in the paint (they're perfectly smooth though). The top part of the spoiler is also VERY faded from the sun. I just want it to look nice again. There aren't any scratches or chips or anything in it.
                • royalflush313
                  • Mar 2004
                  • 2070
                  use 400+, and then wet sand with a 600-800, it will be very nice and smooth.
                  from the sounds of it, I'd just spend fair bit of time sanding, and dont even use primer.
                  ~ Go Canucks Go! ~
                  • hamann318is
                    • 3382
                    What if the spoiler is cracked and faded along the top? I'd like to repaint mine too, but I'd like to do body color.
                    The BMW 318 is back. With a vengeance.
                    • kencopperwheat
                      King of Kegstands
                      • 14396
                      No Primer? Doesn't it promote the adhesion of the top-coat?
                      • royalflush313
                        • Mar 2004
                        • 2070
                        the primer can fill the pores and what not in the surface, so it will allow the top coat to go on nicer. However, if the lip is in a nice shape, and you do a good prep job, i'd skip priming.
                        Also, the lip is located low, and you are bound to get rock chips pretty fast. I myself wouldn't worry about absolute perfection. If anything, I'd throw on a nice coat of clear coat to give it a little bit of protection.
                        ~ Go Canucks Go! ~
                        • kencopperwheat
                          King of Kegstands
                          • 14396
                          Also, [b]the lip is located low[/i], and you are bound to get rock chips pretty fast. I myself wouldn't worry about absolute perfection. If anything, I'd throw on a nice coat of clear coat to give it a little bit of protection.
                          I have an "is" trunk-lit spoiler, NOT the "is" valence lip. The spoiler is made of dense painted foam... the lip is made of plastic.
                          • royalflush313
                            • Mar 2004
                            • 2070
                            oops sorry. I thought you were talking about the is valence lip.
                            Maybe prime would be a good idea then. Either way though, spend some quality time prepping it. Once you throw the primer on, let it dry, and wet sand again if u want it to be nice and perfect.
                            ~ Go Canucks Go! ~
                            • Rob
                              • 8166
                              there was a thread like this a while ago.
                              I used 3m bumper spray, no primer, no sanding, no cracks or peeling in the last 10 months
                              BEERTECH
