anyone ever get these bolts off? (bumper core)
  • guibo09
    • Dec 2008
    • 834
    pic stolen from another thread.
    anyone ever get these bolts off without strippin em? they look so fragile, and my first attempt resulted in a broken torx bit.
    can the bumper core take heat? maybe some torch action helps to loosen things up?
    90 E30 325i
  • kronus
    • Apr 2008
    • 13032
    If you don't care about the bolt getting messed up, slot it with a rotary tool and use a flathead screwdriver.
    cars beep boop
    • DCColegrove
      • 2748
      Whack it straight on the head first...
      We call this worrying the bolt... (I don't know why... It's English) but it will usually release the threads.
      Use a good quality (and the correct size) Torx bit.
      • e30this
        • 3580
        I always just grind them off and put different bolts in when Im done.
        • asubimmer
          • 6482
          weird mine came out just fine?
          • guibo09
            • Dec 2008
            • 834
            will i really be able to put down more torque with a flat head screwdriver than a torx?
            when you grind em, how do you remove the remaining part?
            90 E30 325i
              • 34839
              he lives in montreal, aka the rust belt.
              • asubimmer
                • 6482
                didn't think of that. Southern states FTW :)
                • Kingb
                  • 928
                  I couldn't get mine out either so I just un bolted the bumper shock and swapped it out.
                  Originally posted by Nicademus
                  My car beats off to that car. :bow:
                  • Huff
                    • 2488
                    Use some PB Blaster and wack it a few times with a hammer. Mine were pretty rusted, but they came out okay. Use the correct torq bit also (T25? off the top of my head)
                    • bmw325csi
                      • May 2007
                      • 4045
                      Your holding the nut on the other side right?
                      harry/harout
                      • guibo09
                        • Dec 2008
                        • 834
                        what nut?
                        90 E30 325i
