Rubber shadowline paint
  • e34john
    • Apr 2006
    • 3599
    Last time I got some, about 8 bucks or so. It is rubber so doesn't really chip and a few thin layers will prevent peeling. I used to cover so much stuff at my old job with that stuff.
    • Jand3rson
      • 37587
      $6 per can at my Home Depot. Also, just so everyone knows, you don't have to sand anything you're applying this stuff to. One of it's main uses is to make grips on the handles of tools, and it doesn't require being sanded first, it will bond regardless. Just clean whatever surface you're applying it to with soap and water, then something like acetone or GoofOff, and you should be fine.
      • kamotors
        • Nov 2007
        • 7102
        true, but if your painting on your car, make sure the surface is scratch free and chip free because I sanded my spoiler really good and it looked nice and flat, but once I got a few layers on i noticed that any imperfections that were their seemed to become more noticeable. also, this stuff is super easy to use, just spray and your good.
        7speedshop.com
        • JJe30
          • 2044
          Good to know.
          • jintermont
            • 601
            looks like im going to home depot in the morning, i have all my trim off already i have been procrastinating painting it, because the sem paint has chipped on my quarter panel windows in 2 months already
            • TerribleONE
              • Jul 2006
              • 501
              wow. this stuff sounds great, i think i will go to home depot in the morning to pick up some cans to experiment.
              1991 318iS swapped w/ euro S50B32
              -Michael
                • 37833
                Wow! A friend of mine wants to shadowline his E30, I will recommend this stuff.
                Grover Beach, California
                BimmerHeads.com
                • Jand3rson
                  • 37587
                  I started doing one side of the car today, and this stuff is a little tricky.
                  It says on the can to put it on heavy enough to get a good, wet coat. It doesn't stay in place while it's drying that well, but I think went too heavy with it at first. I'm doing the trim while it's on the car, and it won't stay at the top edge of the trim, it's all running down the angled parts of the trim and forming big globs, and everything at the top edge is piling up at the bottom edge. But like I said, that's my own fault.
                  I'll say this though, it peels off really easily! But not to a fault, it sticks REALLY well. I can't see any issues with it chipping, ever. It literally comes off like the consistency of a rubber glove. It literally took me 5 minutes to peel it all off, and I got each section off in one continuous piece, so don't be mad if you fuck up the first time!
                  I'm probably not even going to bother masking the other side, the overspray literally rubs/peels off. But the areas you want it to stay in will stay stuck for good, as long as you don't peel it up. This mod is 100% reversible.
                  One more thing, it also looks really thin when it first goes on, so don't get to worried about it not looking right. It darkens up as it dries.
                  • Jand3rson
                    • 37587
                    First side is done, I'll have to get some pics later.
                    MAKE SURE you have a damn sharp razor blade around, you're going to need it to cut between the tape and the parts you just painted, otherwise you will pull huge chunks of it off. And you're probably going to in a couple of tiny spots. Just peel SLOWLY.
                    • kamotors
                      • Nov 2007
                      • 7102
                      very cool, cant wait to see pictures.I think I'll give it a try.
                      7speedshop.com
                      • Jordan325iC
                        • Aug 2005
                        • 1697
                        Sweet find! I was just looking at my chipped "shadowline" I did last year and trying to decide what to do with it.
                        '88 325is
                        VP UT of Austin Autoholics
                        BMWCCA 380364
                        • rafiki
                          • 245
                          this is the most badass shit that ever came out of a can. did all my trim and lower lip today. 10000 times better than it was. awesome find.
                          • jintermont
                            • 601
                            just picked up three cans today i have only done my kidneys so far but damn this stuff works great and i got 3 cans for under 20 bucks
                            • Jand3rson
                              • 37587
                              Have you tried peeling it off anything after it dries? It's actually fun. :D
                              • Stephen
                                Шлем ишака
                                • 10774
                                Hmm i might give this a try. Im just not sure whether or not i like shadowline for my car
