Fixin' a fender-bender
  • E30Idea
    • Mar 2007
    • 2196
    #31
    All I have is some 120, can I use that? If not, I guess I've have to go get some 220 tomorrow.
    120 is way too coarse IMO
    ** Lot's of M20 turbo parts for sale.**
    Turn key track car.
    http://www.r3vlimited.com/board/showthread.php?t=222066
    • DatUtahGuy
      • Jan 2007
      • 3146
      #32
      The rule of thumb is you sand the repaired area(body filler) with 240, then sand the primer/final sand with 320 and then you can seal and paint.
      Use something finer, 400 or 500 grit if you don't plan on using a sealer.
      When doing paint work, cleanliness is next go Godliness.
      YOUTUBE: AR Perez
      If lucky, the E36 will die peacefully, in its natural habitat, and be given the prestigious honor of donating its parts to an E30
      • Jand3rson
        • 37587
        #33
        Sanded the fender down with 220, wiped it down with acteone 3 times, and just put the first light coat of self etching primer down.
        • Jand3rson
          • 37587
          #34
          All done with the self etching primer:
          Who votes I do my whole car this color? :D
          • e30this
            • 3580
            #35
            Looks good ninja...
            • AndrewBird
              The Mad Scientist
              • 11898
              #36
              Damn, it turned out straighter then I thought it would on the front. Shouldn't need much of anything to smooth it out.
              • vivalegreg
                • Apr 2006
                • 1313
                #37
                nice work way to go
                e30s r kool
                • Jand3rson
                  • 37587
                  #38
                  It's bumpier in person than in the pics. My camera is ghey.
                  • Stephen
                    Шлем ишака
                    • 10774
                    #39
                    Yes! flat olive!
                    • madformx5
                      • 817
                      #40
                      I like the flat olive too Mr. Anderson. I think you should go with it.
                      • madformx5
                        • 817
                        #41
                        What happened to the engine in your car? Is it there and the angle is just to bad to see it?
                        • Jand3rson
                          • 37587
                          #42
                          The block is there, that's it. The whole top end is removed for maintenance and upgrades.
                          • Jand3rson
                            • 37587
                            #43
                            Just dropped the fender off at a body shop, they're going to tackle the rest of the smoothing, prime and paint it for me for $200.
                            • Jand3rson
                              • 37587
                              #44
                              Got started repairing the damaged corner of the bumper tonight. I used a razor blade to trim out all of the mangled plastic, then sanded it smooth. Once I got the shape all close to normal, I roughed it up with 120 grit and filled the damaged area with plastic weld. Turned out really good, I'm going to sand it tomorrow and get it shaped.
                              • Desaevious
                                • Aug 2007
                                • 3810
                                #45
                                That came out well. Because you didn't have a massive area to patch up it looks great. How was handling the filler? I recall posting how I had to use a good amount of tiger hair to do mine.
                                SC*AR (Schwarz Army)
