Broken sunroof
  • hella 325
    • Sep 2004
    • 380
    Broken sunroof
    Hey guys my sunroof broke in the closed position. It makes a horrible noise when you try to tilt it or open it. What would be the easiest way to fix it? (i do have another sunroof i just need to swap them. But i have no idea how to do this. Will i have to take the headliner out? And if i do that will i have to take the glass out? thanks guys.
    Russell
    1987 325is
    1992 240sx coupe
    1994 525i
  • hella 325
    • Sep 2004
    • 380
    anyone?
    Russell
    1987 325is
    1992 240sx coupe
    1994 525i
    • Bill 84 318i
      • 1600
      To remove the sunroof panel (which I don't think is your problem), you open it like halfway. Then pull the front of the headliner piece down, and it will unclip. Slide that back into the roof and you can access the 6 mounting bolts.
      Is it a power sunroof?
      • hella 325
        • Sep 2004
        • 380
        yea power, its stuck closed i cant open it
        Russell
        1987 325is
        1992 240sx coupe
        1994 525i
        • Bill 84 318i
          • 1600
          Isn't it possible to open power sunroofs manually somehow?
          • UNHCLL
            • 8790
            yes, with a crank that should be in the tool kit. you pop off the black cover next to the switch and start cranking.
            if he's got a horrible noise and the roof refuses to move, i'd bet its the cables... which means manually cranking it wont do anything.
            Below the radar...
            • hella 325
              • Sep 2004
              • 380
              i turned the 17mm nut under that cover at it appears that it is motor tension control. (it does nothign fo rmy problem)
              Russell
              1987 325is
              1992 240sx coupe
              1994 525i
              • UNHCLL
                • 8790
                its an allen wrench in the shape of a Z
                Below the radar...
                • hella 325
                  • Sep 2004
                  • 380
                  o...must be missing....ill tyr a regular hex head
                  Russell
                  1987 325is
                  1992 240sx coupe
                  1994 525i
