small step to making a good car. =]
  • simbas_e30
    • Jan 2010
    • 47
    So i took off all the stickers that were left on the car,
    planning on buying some springs to lower it. and tucking the bumpers soon.
    hopefully getting a new paint job.
    any other ideas?
  • jonmon6691
    • Aug 2009
    • 252
    Originally posted by simbas_e30
    any other ideas?
    Timing belt.
    <-- F*** that guy
    • simbas_e30
      • Jan 2010
      • 47
      why the timing belt?
      • Wh33lhop
        • 11705
        Do you know the last time it was changed?
        paint sucks
        • simbas_e30
          • Jan 2010
          • 47
          nope, but the timing feels fine.
          • Wh33lhop
            • 11705
            nope
            That's why.
            paint sucks
            • simbas_e30
              • Jan 2010
              • 47
              haha ok,
              do you know how much they are?
              is it a hard fix?
              • Wh33lhop
                • 11705
                First thing I did on my E30 was the timing belt and water pump. If you don't know the last time either one has been done then do them both, ASAP. If your timing belt snaps, kiss your engine goodbye.
                I paid about $200 for a new timing belt, belt tensioner, new accessory belts (few bucks a pop, why not), cam seal which I forgot to install, and a good water pump. It took about a weekend.
                In a nutshell:
                Drain coolant
                Remove hood
                Remove belt fan
                Remove radiator
                Remove accessory belts
                Remove timing covers
                Remove and reinstall timing belt/tensioner/water pump
                Make sure timing is spot on (TDC marks line up with proper tension)
                Put everything back together and bleed coolant
                There are plenty of writeups if you look around, try Pelican Parts
                After you're done with that you might want to do a valve adjustment, and change the oil/filter if you don't know when that was last done either, typically people use 10W30 or so in these motors but generally 20W50 is better suited to the car. Just grab some 20W50 Castrol GTX or Valvoline VR-1, don't bother with synthetic stuff in an M20.
                paint sucks
                • reelop19
                  • Jan 2010
                  • 770
                  Solid advice, orrrrrrrrrrrrrr.....you could have a nice car that doesn't move from the driveway.
                  • simbas_e30
                    • Jan 2010
                    • 47
                    In a nutshell:
                    Drain coolant
                    Remove hood
                    Remove belt fan
                    Remove radiator
                    I have an M10.
                    I already did changed the plugs, oil filter, ail filter, distributor and cap, wires, oil, coolant, all that other stuff.
                    It runs fine, just needs some more cleaning.
                    Im working on that.
                    When i get the money i will replace the timing stuff.
                    • IRON-E
                      • 16548
                      I have an M10.
                      Im working on that.
                      Well then, you go ahead and clean the shit out of your car so it can be that more functional and do us all a favor and burn that slow ass m10., once you're done with that comeback for an M20 swap in your clean e30.
                      @IRON-E30 aka Edwin:D
                      • simbas_e30
                        • Jan 2010
                        • 47
                        i want to do a m20 swap, but dont have the money for it right now.
                        Im working on it though.
                        • JasonC
                          Site Manager
                          • 14451
                          I'd boost the m10 before doing a m20 swap.
                          1992 BMW 325iC
                          1978 Chevrolet Monte Carlo
                          • simbas_e30
                            • Jan 2010
                            • 47
                            That has crossed my mind.
                            I kind of want to keep the m10. just because the weight difference between the m10 and m20.
                            • IRON-E
                              • 16548
                              if you don't even want to take the time or money to upkeep your current M10, how are you going to be able to fix it once you put the TeRDBO and or an M20 swap?
