1. Is slight condensation within the housing normal under very wet conditions? I would assume yes because they are not completely sealed.
2. A rock hit one of my lenses last night a there is a hairline crack in it. I'm affraid that the constant heat fluxuation (cold air outside, hot bulb inside) will cause the crack to spread. Is there anything that can be done to stop the crack from spreaking? I was thinking about painting a very small amount of epoxy on the outside of the lens on the crack.
