Hood emblem on trunk?
  • ///Bimmerfan
    • Dec 2008
    • 730
    Is it possible to use the thinner BMW hood emblem on a e30 trunk instead of the thicker one that comes on them?
  • devon.818
    • Feb 2011
    • 2937
    yeah. and vice versa.
    it just wont look perfect up close.
    easier using hood on trunk than trunk on hood.
    trunk on hood makes it look like your e30 has a pimple
    • ///Bimmerfan
      • Dec 2008
      • 730
      Okay, That's what I want to do, put a hood emblem on the trunk. What is an easy way of removing the rear trunk emblem? I tried to pry it off a little bit but it didn't budge. Thanks for the help
      • Harry's E30
        • 643
        keep prying it should come of
        BUILD-http://www.r3vlimited.com/board/showthread.php?t=242728
        • ///Bimmerfan
          • Dec 2008
          • 730
          Okay I will give it another try. Thanks again!
          • boogs325ic
            • Jan 2010
            • 30
            yes u i have one on my trucklid
            • devon.818
              • Feb 2011
              • 2937
              use a thing screw driver or a razor blade under it, go side to side.
              it has rubber gromits that hold it on. litteraly pops off. impossible to damage the badge or holes unless you forest gump the hell outa it...
              • ///Bimmerfan
                • Dec 2008
                • 730
                Ha ha okay sounds good I will give it a go tomorrow ;) Thanks
                • reelizmpro
                  • 9553
                  You can but it just won't fit right and looks ghetto being that the trunk emblem is convex. I would get the correct emblem.
                  88 M3 - LACHSSILBER
                  89 M3 - ALPINEWEISS II
