DB -> Plastic
  • Mr. Tasty
    • Jul 2011
    • 3421
    DB -> Plastic
    I have a 1987 325e, which means I have the notorious "Diving boards." There is a local who is selling the plastic bumpers along with the mounting items. Will this be a direct bolt on? What would I need to do? Also do the valences with DB's work with late model plastic bumpers? Thanks
    copied link
    2014 Alpine White 335i MSport
    (Daily Driver)
    Full Mperformance Aero
    KW V2 Coilovers
    VRSF Catless Downpipes
  • AbsorbantNut
    Non faccio funzionare questa merda
    • Jun 2010
    • 2491
    The front will be a direct bolt on after you cut the tow hook off. The rear bumper needs to be shortened on the sides to fit and the rear bumper shock holes need to be slotted upwards, so the bumper will sit flush.
    '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
    • Mr. Tasty
      • Jul 2011
      • 3421
      Is the amount of work worth the change?
      (Daily Driver)
      KW V2 Coilovers
      • AbsorbantNut
        • Jun 2010
        • 2491
        In my opinion, yes. I'm doing it on my car. I just think that nothing beats the look of plastic bumpers on early model cars, except for maybe an mtech I or II kit.
        • MaxBell
          • 1390
          I'm in the parts collecting stage right now and early starting work, I have start tackling the bumper prep. Not too bad a project so far. My issue is trying to get the rusted diving boards off. I think I may just cut the shocks and get em off that way.
          REMEMBER: Be safe and have fun is Rule Number 1.
          The Epic Unbuild of Clint Eastwood
          • Mr. Tasty
            • Jul 2011
            • 3421
            so update. Installed the front plastic bumper. The mounting equipment gets in the way. I have a 1987 325e front valence on, and it seems like thats what is getting in the way. Do I need to get a different front valence so I can use the mounting brackets on the sides? As of now, the bumper shocks are the only thing keeping it on, and the sides are not sitting correctly
            (Daily Driver)
            KW V2 Coilovers
