Rust spots under the spare wheel (underneath the car)
  • a3ternus
    • 643
    Is there anything I can do about it ?!?
    Could I possibly stop the rust from expanding ?!?
    There are 2 small circular spots 4cm in diameter ie not much,but you notice them...
    A3TeRnuS
    Originally Posted by aaron_silva
    It is always frustrating having a harsh ride when
    you arent in the right mind set.
    • 34847
    you could grind them out and primer them to keep the rust from spreading. If you have rust there you probably have other problems too, like a leaky trunk seal, antenna grommet or maybe tailight gaskets..
    • rs4pro3
      • 5808
      one of my 318i's had this problem also but the whole floor under the spair tire was rusty. I used a wire wheel in my drill and ground away the rust then Brushed Rust convertor on which turns the rust to primer. I put like three coats of that on then sprayed over it with some color that was close to the factory color but not a perfect match.
      85 325e 2.7 ITB'd stroker
