painting kidneys
  • King Luis
    • Sep 2004
    • 737
    painting kidneys
    how do i remove the silver kidney part from the frame/piece thats its on?
    i see the pin things on the top and bottom but they don't budge when i try to pop them out....i don't want to break them....is there any other way?
  • E30Driv3R
    • May 2004
    • 1169
    Try and pull them they wont break.
    Dan Zickel
    1995 M3, 1991 318iS, 1987 325iS
      • 34844
      I broke them out and replaced them with screws.
      • Brew
        • 3060
        Push the center pin through, then pop the larger piece out.
        '91 318is
        • King Luis
          • Sep 2004
          • 737
          i guess i really have to force them out...cause i tried pushing them with a little bit of force and they didn't budge
          • ToplessE30
            • 4791
            It should work, I did mine that way, you just have to work at it.
            Estoril E36 M3/4/5 | Toledo E53 X5 3.0 | LeMans E90 335D M-Sport
            • RCWells
              • 3589
              With some difficulty I used a small screwdriver to push them out and reused the same pins afterwards. Just tedious is all.
              [THE 501 club - Founding Member]
              • jajou318
                • Jan 2005
                • 1023
                Yea they won't break but when you pop them out make sure you have your hand over them that way you don't loose them.
                • King Luis
                  • Sep 2004
                  • 737
                  well i lost it and ended up drilling those pins out...but i painted them and found out my kindneys are all scratched up and screwed. so i'm going on the look out for good condition kidneys that i can paint.
