DTMFiberWerkz Vs Ireland Engineering Flares
  • CrazyB
    • 420
    Anyone have experience with either of this. I am about to start working on fitting 17x9 wheels with 255/40/17 tires on them so i know i will need flares for sure.
    Not sure with which one to go or if there is a third simple option.
    AutoCross Photos!!https://picasaweb.google.com/eugenes18t
  • Eric
    • 5142
    I've ran both. First the IE flares (2002 turbo copies)
    Then I moved on to the DTM flares:
    The DTM flares are wider, but heavier and easier to crack with a solid hit from a tire. The IE flares have less flare but can take a beating. Also eurostop charges far far to much for shipping.
    You can easily fit 255/40/17's with the eurostop flares, but it might be tight with the IE flares. I'm currently running 245/35/18 Kuhmo XS's on 18x9.5 et22 CSL reps. 10mm spacers in the front to clear the strut and 5mm in the rear.
    • einstein57
      • Jun 2007
      • 10780
      My eurostop flares have way more lip then yours eric. You said the guys just slapped yours on but it looks like they did some trimming.
      www.gecoils.com
      • Eric
        • 5142
        Inner lip? Nothing an air die grinder can't quickly remove! Got any pics of your setup? what tire/wheel spec are you running?
        • IronFreak
          • Dec 2012
          • 3702
          Bringing this back to life. I have a set of Eurostops on there way to my house, I'd like to see some r3v guys that are rocking them. I'd also like to know what your wheel/tire specs are so I know what I can and can't do!
          Thanks!
          Instagram @rebellionforge
          • Wild Ride
            • Apr 2008
            • 739
            Is there a way to mount them without drilling holes and taking a die grinder to the original fender lips? Like 3M double sided foam tape?
            I have some 17x9.5's I want to run with some real meat.
            • IronFreak
              • Dec 2012
              • 3702
              Without cutting the original fender your completely defeat the purpose of running flares. you have to remove the original fender flare to get bigger tires and wheels.....hence extending the flare with after market ones. As far as the tape goes I'd say no. flares usually need a little massaging to get them to fit right.
              • rev3030
                • Apr 2013
                • 58
                massive wheels and tires
                • Wild Ride
                  • Apr 2008
                  • 739
                  It is so hard to bring myself to cutting up my beautiful body
                  • Eric
                    • 5142
                    then dont do it.
                    Honestly unless your running some stupid 450hp setup, 235/40/17 fit under the stock fenders and GOOD TIRES will give you adequate traction. If you have traction issues now, throw away the nikangs and buy proper sticky rubber.
                    Here is my 260hp E28 M5 on 225/50/16 RS3's motoring just fine at last weekends 70mph auto-x.
                    • Wild Ride
                      • Apr 2008
                      • 739
                      Haha love your driving music.
                      Honestly though I am whoarding some amazing 17x9.5" wheels that will need flares to run a beefy tire especially as my end goal is V8. Plus I just love love love the look of widebody street cars.
                      • Northern
                        I like cupcakes & sh!tboxes
                        • 5283
                        I like how eric's ie flares worked out (not as much as the esm or ultrawide kamotors though) but if i remember correctly it took a lot of work to get them to look less '02-ish. Normally they just look wrong.
                        Originally posted by priapism
                        Originally posted by shameson
                        • kamotors
                          • Nov 2007
                          • 7102
                          my flares:)
                          7speedshop.com
                          • isEEapex
                            • 4
                            KaMotors, what did you use to make the gaskets between the flares and the body? Also, those dont look like rivets...I am curious, as I would like to be able to easily remove my flares. Any info would be great thanks :)
                            • kamotors
                              • Nov 2007
                              • 7102
                              its fender welting, and I use self tapping screws for easy removal
                              7speedshop.com
