Hey guys, 3m double sided 5lbs tape will do it? Or do i have to use any screws?
How did you install your ryan g splitter?
One of the best threads you will ever read
http://www.r3vlimited.com/board/showthread.php?t=221813
Nice trailer of my e30
http://www.youtube.com/watch?v=TTjtG...e_gdata_player
If i sold you something please leave feedback here
http://www.r3vlimited.com/board/showthread.php?t=217142Tags: None -
I used 12 screws and double sided tape. Tape on its own is not enough. -
89 E30 S52
Transaction Feedback.Comment
I bought it from a member here on r3v a while back..
What type of screws? Will rivets do it?
http://www.r3vlimited.com/board/showthread.php?t=217142Comment
You could use rivets or screws. If you have tendency to drag it, the rivet heads are thinner and will not last as long. You could use self tapping teck screws if you do not have a drill.
The best way to go would be to mark and drill it then use something like an 8mm screw and a AN washer on each side followed up with nyloc nut. This way you are not relying on the plastic to hold it tight be the nut and screw to do the work.seien Sie größer, als Sie erscheinen
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
I used 12 short self tappers and spread them as evenly as possible. I've even ran over my lip 2-3 times when I was low and the splitter saved it from braking., the screw points changed since for me but it works just fine.@IRON-E30 aka Edwin:DComment
I used the self tapping screws he included and no tape...they can be purchased at any hardware store if you need em. That splitter looks mean on there...sigpic2000 323ci
1987 325is super etta
1988 M5
2000 M5
1989 944 turbo
1989 325isComment
Cabron Fady que clase de pregunta es esta? jeje Screw that bitch on!sigpic
1986 "C2 2.7 Alpina" Sedan
1987 325ic Black Vert
http://www.r3vlimited.com/board/showthread.php?t=170548Comment
Luis que tu haces bumping old as shit threads...
This is how i ended up doing mine,
^ That is awesome, that thing will never be falling off with that hardware haha :)
Pics of whole car with splitter installed?Comment
