Deleted Door Mouldings?
  • Super Eta
    • 1884
    What do you guys think of deleted door mouldings?
    What is the best way to delete them?
    My car will be getting a repaired of all the defects and i need door mouldings but i kinda like the look of them deleted and the plus side is that i will save a few bucks. :P
    Here is a picture of what i am looking to do. (I hope you dont mind Jordan)
    Jordan how did you do the process?
    BTW how do you lock and unlock your doors?
    Im assuming Keyless entry wich i am sure is on order if u dont have it already. :P
  • Jordan
    • 12916
    remove the side moldings, fill the channel with a fat thick bead of weld, grind flush, fill small imperfections with plastic filler, prime, paint.
    Look to spend at least 1k for the work.
    keyless entry.
    https://mtechniqueabs.com/
    • LikeCDoos
      • Jan 2004
      • 2522
      I like it but is too much work and money. If you've got the money then do it.
      Jordan, i can't wait for the day when your car is completly done.
      • rwh11385
        lance_entities
        • 18403
        yeah, this was talked about before.
        it would cost was too fucking much. Jordan described it in much detail and it sounded like a muck-nasty job to do. Only he probably has the effort to pull it off. :up:
        • Super Eta
          • 1884
          Of course cuz i dont have a welding machine, plastic filler, primer and paint nor a grinder either. :P
          • Digitalwave
            is a poseur
            • 6299
            Re: Deleted Door Mouldings?
            That's what you think.
            RISING EDGE
            • Super Eta
              • 1884
              Yeah guess i was a bit wrong huh.
