ACS Mono Wiper Fabrication
  • IronmanE30
    • Sep 2009
    • 2121
    I made another bracket to support the drivers’ side of the wiper assembly.
    I use some aluminum that I had in the shop but bending it created a crack.
    Then I tested all of the assemblies with the stock long arm wiper blade. The colors for the different assemblies are the same as yesterdays post. You will notice that I was able to make the wiper stop in the center of the window. I can also change the docking to the passengers’ side like the original ACS cars were made.
    Then I compared the sweep difference between the stock wiper arm and the ACS wiper arm. I found that you loose a little bit of area seeing that it is shorter than the ACS arm but the unit would still work for a Hartge setup which is good news. The blue tape in this picture is of the ACS wiper arm compared to the Red which is the stock wiper arm. The Mtech has a Hartge theme so I will use the stock arm on that car and use the ACS arm on the M3. As you can also see in this picture the ACS wiper arm needs a little different timing on the motor stop position than the stock wiper blade.
    I made another bracket for the drivers side of the wiper assemble. After some research I found out that what I did wrong was to use the vise to bend the aluminum and your radius should be 1 to 2 times the thickness of the material so it won’t crack. So I used an old wrench that had the proper radius and made the second bracket. It worked perfect.
    ACS drilled a hole in the back lip of the gutter at the top of the firewall. Others drilled the hole in the bottom of the gutter which would be easier but would also be in an area where water gathers so I will go with the ACS design once again. I still need to drill the hole but with the bracket is fitted correctly the wiper assembly does not move however without that last bolt I am sure it would develop a rattle. So I have to drill a new hole in the body which is not my favorite thing to do. Then I timed the motor to stop the wiper blade on the passengers side put some soapy water on the windshield and did the final test. It’s hard to see in the picture but the blade stops at the rubber molding on each side of the windshield so there is no need to lengthen the spacer in the wiper assembly arm.
    All I need to do now is to take out the prototype wiper arm assembly to use it as a template to fabricate another one for the M3 and then button up both cars. Hopefully I will have it installed on the M3 for the SoCal Vintage meet next month. I hope to see you guys there.
    Cheers,
    Jim
    • IronmanE30
      • Sep 2009
      • 2121
      I made a bracket to support the drivers’ side of the wiper assembly.
      I made another bracket for the drivers side of the wiper assemble. After some research I found out that what I did wrong was to use the vise to bend the aluminum and your radius should be 1 to 2 times the thickness of the material so it won’t crack. So I used an old wrench that had the proper radius and made the second bracket. It worked perfect. ACS drilled a hole in the back lip of the gutter at the top of the firewall. Others drilled the hole in the bottom of the gutter which would be easier but would also be in an area where water gathers so I will go with the ACS design once again. I still need to drill the hole but with the bracket is fitted correctly the wiper assembly does not move however without that last bolt I am sure it would develop a rattle. So I have to drill a new hole in the body which is not my favorite thing to do. Then I timed the motor to stop the wiper blade on the passengers side put some soapy water on the windshield and did the final test. It’s hard to see in the picture but the blade stops at the rubber molding on each side of the windshield so there is no need to lengthen the spacer in the wiper assembly arm.
      Cheers,
      Jim
      • prada88m3
        • Dec 2010
        • 211
        nice job!!! do you have a part# for the euro grill or the cap
        • IronmanE30
          • Sep 2009
          • 2121
          Thank you,
          Here is a picture of the Euro air vent grill with part number, as far as the plug goes I would guess that any good hardware store would have them.
          Cheers,
          Jim
          • Skunkworks
            • Sep 2012
            • 436
            that is awesome. thanks for sharing...
            • robrez
              • Jul 2008
              • 3376
              Great work Jim. Can't wait to see it next week.
              January 2012 COTM
              • IronmanE30
                • Sep 2009
                • 2121
                Thanks, I'm glad you like it.
                Thanks Robert,
                It will be nice to see you and your little puppy at the SoCal Vintage event. My work has picked up so it's all I can do to get the car ready for the show. I won't have time to get the mono wiper on the M3. I will finish off the M3 once work slows back down. It will be nice to see what you have done to your car since last year.
                Cheers,
                Jim
                • ngampleh
                  • Jul 2012
                  • 466
                  I just did it full sweep and center stop on RHD e30
                  so, excited after failed with RHD linkage
                  I did this rice project since March, 2014..
                  and succeed after read this thread..
                  [ETA - E30 Adapters] 5 Lug kit with e46m3 front and e46 325/328i rear brake setup
                  [ETA - E30 Adapters] - 5 Lug kit | DTM Shifter | DSSR
                  Transaction Feedback
                  • TimeMachinE30
                    • Jun 2014
                    • 3749
                    Did you grind or press out the pins?
                    ACS S3 Build / Dinan 5 E34
                    • IronmanE30
                      • Sep 2009
                      • 2121
                      I am glad that this thread helped you get your mono-wiper setup. It's was a fun project.
                      Cheers,
                      Jim
                      • ngampleh
                        • Jul 2012
                        • 466
                        no, just cut between pin and shaft
                        add 10mm then TIG weld it
                        stock length was 29.8mm, from center pin to center shaft (you can clearly see it)
                        after mod is 39.8mm
                        I use my RHD linkage/plate to increase the length
                        • ngampleh
                          • Jul 2012
                          • 466
                          Cheers,
                          Jim
                          honestly, I did it on RHD linkage.. full sweep and center stop
                          but, it hit the blower cover..
                          so I gave to my friend track car, cos he didnt use AC/heater
                          then, I imported LHD linkage and motor from US (from r3v member here)
                          installed it to RHD car..
                          PITA to installed in RHD car, lol
                          • TimeMachinE30
                            • Jun 2014
                            • 3749
                            My question remains.
                            • IronmanE30
                              • Sep 2009
                              • 2121
                              It's been a while since I looked at the pin but as I recall it has a round end on both sides so I ground off one end and used a punch to remove it.
                              Cheers,
                              Jim
                              • stonea
                                • 2890
                                Pretty nice job, a mono wiper has always been on my to do list.
                                My Garage
                                Feedback
                                Instagram: Stone.Hopkins
