Quick question: What size torx/hex bolt for plastic bumper cover?
  • tryp2nite
    • Jan 2004
    • 58
    Can anyone tell me what size torx or hex bolt is used to secure the late-model plastic bumper covers? Front and rear?
  • T.Dot E30
    • Mar 2004
    • 536
    There are Two Trox bolts used to secure the front and rear rebar to the car.
    Underneat the bumper trims are plastic push in clips that attach the Bumper Cover to the rebar.
    I just wanted to correct you that the trox bolts dont hold the bumper covers on.
    I can't remember exactly what size, i have a full set and just grab the one that fit.
    in this article they say its a 13mm.
    But aren't trox bits, T6, T7, T8....etc?
    • Digitalwave
      is a poseur
      • 6292
      The fronts you can use a 10mm allen key on. The rears I believe are the same but I am not sure.
      RISING EDGE
      • tryp2nite
        • Jan 2004
        • 58
        You're right, TJ.
        I used the 10mm allens for the torx on front and rear. Those fuckers were on TIGHT!
        Thanks for all your help guys.
        • bmwm3n528
          • 3654
          Be careful doing so though, almost rounded one of the bolts with a 10mm hex.
          Torx aren't that expensive.
          Trevor Ely
          '95 M Sport 540i - '00 A4 1.8TQMS - '85 190E 2.3-16
          '88 535is - '87 325e - '89 325is - '91 318is - '90 325is - '96 328is
          • fporro
            • 1859
            t10 heck's
            • MitchFong
              • Sep 2005
              • 665
              I was usinf t55 i beleive.
              But one of mine wouldnt come off, broke 2 torx bits, a socket wrench and my pride lol. it wouldnt budge ahha
              • e30evolution
                West Werks
                • 1888
                t55
                http://www.westwerksauto.com
