Painting engine
  • eliasmavs99
    • 58
    Painting engine
    I know people paint their valve cover and air "intake" ports or whatever. What kind of paints have you used? What color works best?
  • bimmerphile
    • 3495
    Dark colors work best for obvious reasons. You will need to remove any cosmoline before applying the high-temp paint (like barbecue paint as some have used).
    Paint with several coats, then put a piece of rough sand paper on a block (relatively rough, like 200 grit) to sand down the lines and BMW. Increase the grit all the way to, say, 5000 if you want to get a very nice finish.
    • LikeCDoos
      • Jan 2004
      • 2522
      how do you get off the cosmoline? i've got a tiny bit starting up on my head
      • Court M3
        • Jan 2004
        • 6713
        Prep work is the key. Make sure you clean it throughly before painting. Had a friend bead blast mine first.
        Spray thin coats to avoid runs in the paint. Let it set overnight, and if you haven't done so in a while install a new valve cover gasket. Should be good as new
        Continuous For Sale Thread
        323i s50
        • Jand3rson
          • 37587
          You can't have cosmoline FORMING on your engine. It's something that was put there by dealers.
          • M42Technik
            • 9781
            ...how do you get off the cosmoline? i've got a tiny bit starting up on my head
            If I recall correctly, you use something called "simple green" and let it sit overnight. Should come right off. I am not sure if that is the right cleaning product though, someone correct me if so.
            Reminiscing...
            • Brew
              • 3060
              I was under the impression that the cosmoline was put on in Germany and the dealers were supposed to take it off when they received the cars. A lot of them never did. And yeah, Simple Green works great at removing it.
              '91 318is
              • bimmerphile
                • 3495
                Yes this is correct.
                Josh: I think Cdoos meant he had some on the head, to elsewhere. Not moving, but just descriptive of location.
                • Digitalwave
                  is a poseur
                  • 6299
                  Simple Green isn't going to take the cosmoline off your valve cover and intake manifold.
                  I used industrial strength paint stripper on mine, it took the stuff RIGHT OFF with a wire brush. The stuff looks like bar-b-que sauce.
                  Then I used engine paint primer and "universal black" on the parts. It looks great.
                  RISING EDGE
                  • bimmerphile
                    • 3495
                    It did for mine and Tara's just fine.
                    BMW also sells a "Cosmoline Remover"
                    • 318driver
                      • 1714
                      TJ, got any pics or your engine bay?
                      90 325is
                      IE stage 3s and refeshed m20....
                      • LikeCDoos
                        • Jan 2004
                        • 2522
                        I think i was under the impression that "cosmoline" was something different than it really is. Can someone explain to me what cosmoline is? I thought it was the yellowish areas that you typically see in older bimmer's engine bays.
                        • Brew
                          • 3060
                          That's what it is.
                          Did you get the springs yet by the way?
                          '91 318is
                          • LikeCDoos
                            • Jan 2004
                            • 2522
                            That's what it is.
                            thats what i thought, springs haven't arrived yet, i'm expecting them either later today or tomorrow. Worst comes to worst they will be here next week. I'm in no hurry. thanks again :up:
                            • Jand3rson
                              • 37587
                              Ah. My bad.
