How to remove front rubber bumper trim on diving board bumpers
  • IS300E30
    • Apr 2009
    • 408
    How do you remove just the rubber trim on the front bumper?
    87 325i, so the diving board bumpers.
    Thanks
  • agent
    Vice Grand Pubaa
    • 7960
    There are pinch clips holding the trim in place. It will be far easier to remove the trim with the bumpers off the car so you can push the clips through from the back side while compressing them with a pair of pliers.
    You can try and pry it off while the bumper is still on the car, but it likely won't end well for the trim where the clips are held.
    Originally posted by kronus
    • Beau B
      • Mar 2004
      • 734
      I would also recommend taking the bumper off first.. it is very easy to take on and off and makes removing the molding 10x easier..
      1988 BMW 325iS
      • IS300E30
        • Apr 2009
        • 408
        How do you take the bumper off then? Is there any diy or can someone give me a detail of how to remove the front bumper?
        • cabin
          • Dec 2006
          • 552
          Look under the bumper for the 2 bumper shocks. There are 2 nuts on each shock attaching them to the car. Remove these and your bumper should come right off. No need to remove the plastic trim around the bumper either. Don't forget to unplug the connectors from your turn signals either.
          -Justin
          Current: BMWless for now... '15 Grand Cherokee & '03 Mach 1
