Cant get fixed Quarter window out. Help!!!!
  • ThatOneEuroE30
    • Dec 2013
    • 8626
    Title says it all. I cant get out at all I've tried all the DYI's I've found including the one here. Help me pleasee.
    1991 318i 4dr slick top
    Mtech 2 turbo restoration
  • kronus
    • Apr 2008
    • 13020
    did you take out the two nuts in the b pillar? After you do, get a bunch (like 6) flathead screwdrivers, and starting from a forward corner, push the window out while working the screwdrivers under the gasket from the inside of the car. Once you get a corner loose, get the other one, then the window should push out.
    cars beep boop
    • ThatOneEuroE30
      • Dec 2013
      • 8626
      yes I took the bolts out.What do you mean by forward corner? and under which gasket inside? the one that runs against the headliner?
      • kronus
        • Apr 2008
        • 13020
        the two 90-degreeish corners that are closest to the front of the car, instead of the one that's toward the back.
        and by under gasket, I mean between the gasket (the one that goes around the window) and the body of the car. The gasket sits on a ridge, and you need to lift it over this ridge to get the window out.
        cars beep boop
        • ThatOneEuroE30
          • Dec 2013
          • 8626
          Alright I''l try this. thanks!
