IX kit, 4DR vs. 2DR Difference?
  • E30Brad
    • Aug 2013
    • 84
    THE FIX IS IN THE SECOND COMMENT.
    IDK if this already a thing, but I think the IX kits are different between 2 door and 4 door. If you look closely at the 4 door, the trim ends short on the rear door and the cut out for the trim on the rear flare is for the lower body line which would line up with say... the lower M3 box flare body line.
    If you look at the 2 door, the cut out would be higher on the flare, for the trim piece on the quarter panel itself, which is longer.
    My car. I think I have a 4 door IX kit for my 2 door.
  • E30Brad
    • Aug 2013
    • 84
    It's not the kits, its the trim pieces. 2 door I's IS's are different part#'s than IX 2 doors. And then you have your 4 door trims. The part#'s are different left to right on them all. So really there should be 6 different part#'s: (I & IS 2DR. x2) (IX 2DR. x2) and (All 4DR's. x2). Plus the part#'s for the ones with chrome. And the same should go for the front fenders trim.
    So, if you're putting an IX kit on a NON IX 2DR car, you will need these part#'s below for your new trim. On 4DR's, You should just need the 2 front pieces changed.
    (THESE ARE THE SCHWARZ BLACK, not with chrome)
    51131967133: FRONT LEFT/ IX 2DR
    51131967134: FRONT RIGHT/ IX 2DR
    51131967135: REAR LEFT/ IX 2DR
    51131967136: REAR RIGHT/ IX 2DR
      • 34844
      Yeah, the flares are the same its the black trim that differs.
