Removing The Sunroof
  • Low Level E30
    • 1646
    How do I remove the liner-thing under the sunroof?
    And then, how do I remove the sunroof?
    Mine is rusted - need to replace the panel.
  • Super Eta
    • 1884
    oh god i tried this i cant figure out how in gods name to put back the liner. :x
    6-8 t25 hex screws are on the sides of the sunroof rails. (in all as in one side will have 3 and the other will have 3)
    Open the sunroof so that back sticks up and push the liner up so you see the tracks now get a light and take a peek on the side of the sunroof tracks if your looking at it right you should see 3 Hex screws.
    Be careful and do not apply to much force or what on it as you may end up stripping them out wich in your case might just happen. They screws will just start spinning in the hole and thats it so be careful.
    Goodluck!
    Ryan
    • Low Level E30
      • 1646
      Goodluck!
      Ryan
      I think I see the screws you're talkin' about ---- so you say just undo those screws, and the sunroof panel will lift right out of the car, basically?
      Gonna hafta go get some hexdrivers.
      • Bryson
        • 1490
        open the sunroof half way, pull the front of the sunroof headliner down and it will unclip from the sunroof panel. Then you can close the sunroof and slide the headliner all the way back as if the sunroof were open to do your work. hth :)
        • Super Eta
          • 1884
          Yep pretty much. Just put my post and bryson's together and it will be out in a snap. :P
          • Low Level E30
            • 1646
            So you're saying open it halfway, as in, slide it back into the roof of the car? As opposed to lifting the sunroof up out of the roof halfway.
            Cool. I'll go try that.
            Cheers dudes!!
