To those with no sunroof E30's / welding up sunroof...
  • UNHCLL
    • 8790
    Originally posted by M42Technik
    Okay so how do I go about unclogging it?
    Open the sunroof
    You'll see 4 holes (1 in each corner)
    Blow compressed air down each one.
    Don't blow massive amounts at high speed, you could dislodge the tube and then you create a bigger issue.
    The rear holes drain in front of the rear wheels I think...
    The front holes drain behind the front wheels.
    You can also stick a plumbers snake down each one to help loosen things up.
    -C
    Below the radar...
    • M42Technik
      • 9781
      Originally posted by UNHCLL
      Open the sunroof
      -C
      Thanks dawg...oh I saw this too:
      I'm FUCKING CRAZY!
      Reminiscing...
      • Rocla
        • 922
        Man, you are crazy, I own 3 non sunroof e30's and I wish they had sunroofs... not fair.
        I had to buy webasto hollandia aftermarket sunroof :)
        EDIT:glass sunroof.
        Current:
        BMW 320i 2d 2.0 m20 -88
        BMW 325i Cabriolet 2.5 m50 -88
        BMW 316i touring 1.6 m40 -90
        BMW 320i 4d 2,2 m54 -01
        • blueapplesoda
          • Dec 2005
          • 1904
          I wonder how much sunroof equipment weights...that would be a good amount of weight lost, wouldn't it?
          • e30 gangsta
            • 3877
            54 lbs i cut it all out. Thats what it weighs.
            • BDSax
              Junkyard King
              • Mar 2006
              • 3594
              ^^^ haha, you the man. SLOPPYNIG STYLE!
              • e30 gangsta
                • 3877
                Thats right. I was reading my suscription of GRM today. They did the same. People used to tell me are you stupid? And i would say, " more head room, cage bars can go higher to the roof, so overall more safety get it?" Then people would tell me but you lose your sunroof blah blah blah. Some people just dont get it. If i were you just cut it out.
                • trent
                  Originally posted by e30 gangsta
                  Is that shooter screwed to the roof?
                  • e30 gangsta
                    • 3877
                    I dont understand what you are trying to say. But if your trying to say her giving the finger towards the roof then yes.
                    • trent
                      no i mean...what did you use to attach the panel?
                      looks like rivits or shooter screws
                      • Ray Smoodiver
                        • Jun 2004
                        • 8809
                        Are the non sunroof pillars solid (no drains?)
                        Could it be that non sunroof cars are more torsionally rigid due to this fact (if they are indeed solid)
                        • mazur
                          • Jan 2006
                          • 731
                          I hate sunroofs. It gave me no headroom with a helmet on in my e36. Don't have that problem with the E30, but just knowing the mass of weight that sits above me just bothers me.
                          CF replacement FTW. My friend did this on his E36 M3 and it rocks.
                          • Rocla
                            • 922
                            They are not solid, if you mean like there is no "tunnel" in pillar, non sunroof car have sama construct as sunroofs, stamped plates spot welded together.
                            Non sunroof cars are a bit more rigid, since the roof panel it self is one piece(without the hole) and the is a better "cross brace" between the B-pillars.
                            Current:
                            • Ray Smoodiver
                              • Jun 2004
                              • 8809
                              Yea I meant would the removal of the tunnel add to rigidity.
                              • blueapplesoda
                                • Dec 2005
                                • 1904
                                54 lbs. i think the sunroof is coming out along with the interior tar.
